06 CRF100F Backfiring on Deceleration
This is a discussion on 06 CRF100F Backfiring on Deceleration within the Bigger Minis Forum forums, part of the General Talk category; 06 CRF100F Backfiring on Deceleration I road race My 06 CRF100F..(Stock Class) My Carb Settings are: Stock Main Jet (new replaced Stock Pilot Jet(new replaced) ...
Results 1 to 15 of 15
Like Tree3Likes
  • 2 Post By davmo
  • 1 Post By PhilRabbleCroteau
Thread: 06 CRF100F Backfiring on Deceleration
    is RACING
    PocketBikeRacingTsmmr's Avatar
    Mar 2011
    NJ
    Needle is one Notch Down..
    Carb Screw adjustments to fine tune the bike to run right..
    Fuel Mixtire screw(no air screw) is new,replaced and set to stock setting..
    Stock Carb,Stock Air Box,Stock Air Filter
    Carb Fully Cleaned.
    Stock Electronics.
    Stock Pipe.
    NGK Plug..Tried the 6,the (CR7HSA ,and the (CR8HSA ..I have the 8 in the bike now(it’s for extended high speed riding}in manual’ as I do)..All plugs do the same pop..no matter what plugs in the bike..
    Plug Color Is Black...Not Soaked Wet,No Caked Oil......but Black after Racing..
    The bike starts right up..Purrs..Great Idle,Great Throttle Response..No hiccups..
    The bike has incredible Midrange response..
    Very Strong Running Bike..
    Racing:First Fast Turn..In 5th Gear Downshifting to 4th Gear Hard Deceleration....POP..A BIG POP Backfiring on Deceleration..
    One pop only..no other popping,no small pops..
    Go around the track twice and it stops,no more Backfiring on Deceleration..
    Our races may be 25 minutes...or less...When I come into pit in neutral the bike has a blip in the throttle but the bike rides fine..
    After the bike cools the blip is gone..
    I could race the bike for an hour straight ,hard riding and I will only get the BIG POP Backfiring on Deceleration twice when first getting on the track in the same turn....
    Is this BAD?
    what should I look into..?
    Do I just live with it since the bike runs so strong?
    However I don't want to blow the motor..
    I have found that if I don’t decelerate as hard the first two turns and run 5th gear into the turn further I get no pop..
    MINI RACING @
    Hidden Content
    NJminiGP kidz at New Jersey Motorsports Park
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    is When minibikes are outlawed,
    only outlaws will have
    minibikes. You can have mine
    soon as you pry my cold dead
    fingers off it.
    davmo's Avatar
    Dec 2011
    Minibike, Texas.
    Popping on deceleration is usually a result of lean condition. Since you say the spark plug is black, you are running rich most likely. Here's my theory: when rapidly decelerating, the gas in the tank and carb bowl will move toward the front of the bike. This can temporarily steal gas from your jets or petcock. There is sometimes a plastic shroud, or built in cup that goes around the jets to keep gas there during turns, wheelies, fast starts or stops. Don't know if your particular carb has one or not, but it is surprising how many bikes I have come across with them missing. If your float setting is a hair low, the problem will be worse. Once you get going out there, your float will allow more gas in the bowl than when you are sitting still, that make it better as long as you are riding. Let the bike idle a bit, even after a ride, and I bet you can get the pop to show up again. I would start with the float setting up slightly.
    is I wanna Ride!!!
    PhilRabbleCroteau's Avatar
    Mar 2011
    The 607!!!! Johnson City N.Y
    awesome question ....one of my bikes in the garage is very similar it just does not go away ...I am going to try to set the float like davmo says, but is there a picture of this said baffle? I bet the jackass that had this engine before might have put it in the "spare parts" bin! its on hard breaking/down shift only and did not even know where to start explaining to ask
    fingers off it.
    davmo's Avatar
    Dec 2011
    Minibike, Texas.
    Quote Originally Posted by PhilRabbleCroteau View Post
    These are pictures of a PE24, and a Mikuni 28mm flat slide. The PE24 has a white plastic shroud, and the 28 has a brass one. Both carbs have a cup built into the bowl.
ID:	120112   Click image for larger version.
ID:	120113   Click image for larger version.
ID:	120114   Click image for larger version.
    is I wanna Ride!!!
    Mar 2011
    ya i have 22mm "mikuni" that has nothing of the sort .......
    fingers off it.
    davmo's Avatar
    Dec 2011
    Minibike, Texas.
    Item #27 looks to be the part on this Mikuni diagram. They list is as a "baffle"
    is I wanna Ride!!!
    Mar 2011
    awesome dude thank you....damn "baffles" I will buy one to try for sure I think I can find one... either way its worth a shot!
    is I wanna Ride!!!
    Mar 2011
    I have had a good run until the last couple of months ....carbs be phucking with me
  10. #9
    is RACING
    Mar 2011
    NJ
    Thank you..
    I know I have the plastic shroud in as the first time I took the carb apart to clean it's pilot jet it fell out and I was like OH NO!!.what was that..
    Now it's pinned in my head never to forget it..
    My float bowl may be to low so I will raise it a tad and report back after my next race...
    Crazy thing with this bike is: I can let it run and run,it won't pop it'll run great,idle great .....if I ride it casual never a pop...Only hard riding and rapid decelerating I get early in race a BIG POP upon heavy decelerating..
    Someone stated:
    Check to see if the valves are too tight.?
    Sounds like you have a burned exhaust valve and leaky valve seals?
    MINI RACING @
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
  11. #10
    is I wanna Ride!!!
    Mar 2011
    that's the same as mine, I cant get it to do it on the stand and it got worse in the parking lot with street tires lol
  12. #11
    is RACING
    Mar 2011
    NJ
    Another thing I'm going to try as recommended by another member here..
    Is:
    Make sure to fully warm up the bike before racing it..
    Set the needle position clip back in the middle..it’s the only setting on the carb that’s different.
    I bring a second carb with slide,the needle is set in the middle so at the track instead of messing with moving the clip I just thrown in the other needle vice versa.
    Note: this is an 06 ..the carbs the vtype without the adjustable needle and fuel mixture screw so I had to buy an older XR100 carb to install those parts..
    MINI RACING @
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
  13. #12
    44dwarf's Avatar
    Dec 2011
    central Ma.
    You may want to make sure the exhaust is well tight and leak free too. On de-cell the exhaust can pop if there is a leak, or you have large open end short pipe like an "Engines only outlaw pipe" which is just a noisy POS and not worth $20 nor the $15 I paid for a used one.
  14. #13
    theraymondguy's Avatar
    May 2010
    Niagara, ON
    The XR100R carb doesn't have the baffle on the main as shown. I do agree that float height is the most likely cause (especially if different size wheels have been fitted).
    Setting float height is easier than you think.
    Level the bike front to rear and side to side, add sag weights or pull the rear down to emulate rider weight. Attach a clear hose to the drain as shown, open the drain screw and the fuel petcock. The fuel level in the clear hose should be even with the carb body (where the bowl and carb body meet). A little high - bike will run rich, a little low- bike will run lean. The float height in the pictured carb is very low (due to suspension and wheel mods).
  15. #14
    is twist the wrist too feel the
    bliss
    ndubstuntz420's Avatar
    Mar 2012
    ^^^that was a good tid bit of knowledge right there thank you
  16. #15
    is I wanna Ride!!!
    Mar 2011
    that is an awesome trick I did not know... thank u sir!!! I will be using this to check all the bikes we have from now on!!!
  1. crf100f
    By crfspeed100 in forum Bigger Minis Forum
    Last Post: 12-12-2012, 12:16 AM
  2. 04 crf100f
    By richb110 in forum Bigger Minis Forum
    Last Post: 02-23-2011, 07:42 PM
  3. 06 crf100f for sale!!!!!
    By bradleyberchem in forum Complete Bikes For Sale - All makes and models
    Last Post: 03-17-2009, 12:26 AM
  4. popping upon deceleration?
    By NCNSR in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 06-27-2008, 02:39 PM
07 xr 100 back fires when slowing down
2008 honda crf100f carburetorsettings
crf 100 backfire
crf 100 backfiring in pipe
crf 100 carb poping
crf100 backfires on deexeleration
crf100f hard to get into neutral when stopped
honda crf100 wont idle backfire
pe24 set float level
xr100 backfires
xr100 backfiring
y is my crf 50 backfiring
