TTR125/YZ85 Conversion
This is a discussion on TTR125/YZ85 Conversion within the Bigger Minis Forum forums, part of the General Talk category; After a little down time, focusing on some personal and family stuff, Its time to get back to documenting a few conversion builds. For those ...
Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    settintrendz's Avatar
    Apr 2009
    Fresno, California
    For those that don't know me, Im mildly obsessed with the XR/CRF100s. I do a lot of CR/XR conversions, but KLX/KX platform is really fun and with the popularity and availability of the TTR’s, we started doing those a few years back as well. This thread will be outlining a TTR125/YZ85 conversion, using one of our kits. All the TTR/YZ ‘s Ive done to date have been 14/17 combos. This will be a 16/19. You guys have seen these bikes in stock form so theres no need to waste space with those pictures. Ive always wanted to do one of these “to the nines” so-to-speak, so… here goes.
    A blank canvas…
    Linkage mount/ relocator...
    Rear master cylinder mount...
    is Ready to ride!
    blake_hughes's Avatar
    Dec 2010
    Fort Worth, Texas and atop the Podium
    Tuning in... =]
    punkguitarist's Avatar
    Oct 2004
    Subbed! Looking forward to following this I'm sure it will turn out badass like all your other builds.
    By the way pics aren't showing up??? It's just a bunch of empty boxes.... By the way could you PM me the prices and details for your yz85/ttr125 conversion kit?
    is 10 year member still has no
    status
    spiz5's Avatar
    Feb 2004
    Frankfort Il
    Pics are fine on my end.
    motorheadparts1's Avatar
    Jul 2011
    Upstate New York
    Sexy welds
    liking this project already!
    Luckystar64's Avatar
    Feb 2007
    Brunswick, Ohio
    Looks great so far! Great to see ya back in action Bro! --L*64
    Apr 2009
    Fresno, California
    Thanks Guys.
    Brake resi mount goes behind the right side plate.
    Now its time to make the mods on the frame for the swingarm. They both share the same diameter swingarm pivot bolt, but The YZ85 swinger itself is narrower than that of the TTR125. That, of course, means that the TTR frame at the pivot is too wide. Instead of just putting a “loose” spacer on each side between the frame and swinger, we machine a little top-hat lookin spacer/weld washer. We then open up the stock swinger pivot hole on the TTR frame and weld them in place. This accomplishes two things: 1) Makes the swingarm now fit without fumbling around with spacers. 2) Makes for a much stronger pivot.
    Next are the mods for the upper shock mount…
    To better clear the frame, and allow for geometry similar to that of the stock YZ85, we move the upper shock mount back and up a bit. “Top-hat” spacers/weld washers, similar to those used on the swing arm pivot, are machined and welded here…
    We can now bolt up the stock YZ85 swingarm, linkage, and shock…
    You can see where the top tube/ backbone is contacting the shock spring at a small point after the bend. We will now trim that back and plate it in.
    greenducky55's Avatar
    Nov 2009
    Fresno, CA
    Looking good keep it up!
  10. #9
    rsjkwells's Avatar
    Jun 2014
    Carmel Valley,Ca
    Adam, Always love your stuff!!! Been following it for years!!! Keep it up.
    -Robbrt
  11. #10
    Apr 2009
    Fresno, California
    Thanks guys.
    Now that we have the rear suspension and brakes sorted, we need to cradle the sucker.
    There we go. All welded up and ready for powdercoat.
  12. #11
    is Who says Big guys can't fly?
    FatManTTR27's Avatar
    Aug 2014
    Florida
    Wow, just wow!!
  13. #12
    Kurlon's Avatar
    Feb 2005
    Southern Maine
    Looks good, could you post a shot of the shock from the other side showing how the piggy back resi clears? For the 19/16 build do you have an actual 'big wheel' swingarm or are you sticking with the YZ85 stock unit? The welded in cradle is nice, does it buy anything over a good bolt in setup ala BBR? Lastly, what's the cost for the conversion service and do you have an 08 or later frames already done up for sale?
  14. #13
    Apr 2009
    Fresno, California
    Quote Originally Posted by Kurlon View Post
    As far as the swingarm goes, for the 14/17 you can run a stock, unmodified YZ80/85 swingarm, linkage, and shock. For the 16/19 combo, like on this build, we cut the back of the YZ swingarm off and weld in one of our modern MX-style axle dropouts. Pics of that mod to come.
    The BBR cradle is good if you want an easy bolt on deal. In fact, its perfect for that. We even have it on one of our test TTR conversions. But it can still stretch those two small tabs where it mounts at the back with bigger or aggressive riders. We do the weld-ins for strength but also for a more factory look and feel.
    Ill post a pic of the resi clearance.
    I don’t have any pre-modified frames. Sorry.
    You can contact me off this forum/site about services. I wont discuss it here for reasons outlined in a previous post in this thread.
  15. #14
    Apr 2009
    Fresno, California
    Gotta prep a few other items for powder coat as well.
    We machine all of our stock hubs to remove all the casting flash as well as ribs, leaving them nuce and smooth.
    Also gotta clean up the clutch and ignition covers...
    While the Ignition cover is off, we will pull the flywheel and put it on a 400g diet.
  16. #15
    Feb 2007
    Brunswick, Ohio
    Coming out great! --L*64
  1. ttr125 in yz85 frame
    By Walters291 in forum Bigger Minis Forum
    Last Post: 03-13-2013, 10:36 AM
  2. Swapping YZ85 suspension to my TTR125.Anyone have any pointers?
    By motomatt94 in forum 2 Stroke Pitbikes
    Last Post: 09-06-2012, 10:25 AM
  3. ttr125 yz85 front end question
    By johnr6 in forum Bigger Minis Forum
    Last Post: 06-16-2012, 01:13 PM
  4. TTR125 w/ YZ85 wheels and suspension?
    By Down2Mob in forum Bigger Minis Forum
    Last Post: 08-25-2010, 04:38 PM
  5. TTR125 to YZ85 swap???
    By corndog125 in forum Bigger Minis Forum
    Last Post: 10-29-2008, 08:31 PM
ttr 125 conversion
ttr 125 swingarm conversion
ttr 125 to yz 85 fork conversion
ttr 125 yz 80 fork conversion
ttr125 convert to yz85
ttr125 with yz85 swing arm
ttr125 yz80 swing arm
will a yz 125 swingarm bolt on a yz 85
yz85 frames
yz85 suspension on ttr 125
yz85 swing arm in a ttr 125
