older ttr 125 help with plastics
This is a discussion on older ttr 125 help with plastics within the Bigger Minis Forum forums, part of the General Talk category; my son bought a 2003 ttr 125 and it could use a little cleaning and fixing up to look good again. the problem is the ...
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By greenducky55
Thread: older ttr 125 help with plastics
    deadman's Avatar
    Dec 2016
    my son bought a 2003 ttr 125 and it could use a little cleaning and fixing up to look good again. the problem is the bike needs new plastics and im having a tough time figuring out what to do and what really works. so here is my questions.....
    will 2008 and up ttr 125 plastics directly bolt on to the older bike?
    I also have read the yz80 rear and front fender from the 93 and up are a direct bolt on.
    my other question is can I put the smaller wheels 14/17 on the big wheel bike?
    thanks in advance.
    greenducky55's Avatar
    Nov 2009
    Fresno, CA
    Hey congrats on the new addition. And welcome to the forum. The plastic update can be expensive. you need the 2008+ fuel tank, and seat, everything else bolts right up.
    The 1993-2001 Yz80/85 rear fender does bolt right up, 2002 and up is not a direct bolt on.
    The 1993+ front fender does require some modification to work. you will have to redrill the 4 bolt holes to match the TTR forks, also you will need to trim the back of the fender so that it does not hit the exhaust.
    I know the rear 14" wheel will directly fit, for the front wheel you need the non L forks because of the front drum brake boss. also you will need a non hydraulic brake perch/lever.
    if you are really wanting a small wheel with new style plastic before you spend any money id recommend selling the current one and spending the money on a 2008+ small wheel it will be cheaper in the end.
    deadman likes this.
    deadman's Avatar
    Dec 2016
    thank you so much. ive been searching the web for days and trying to figure out through pictures what works and don't work and nobody could give me solid answers. so from what I gather the 08 and up frame is basically the same. is that correct?
    deadman's Avatar
    Dec 2016
    I was able to lower the suspension enough by moving the forks up to the bars and taking some tension off the rear shock. with a little growing over the winter we wont need a small wheel conversion.
    Nov 2009
    Fresno, CA
    Frame is the same some variances with electric start and non electric start frames but that's about it.
  1. Wtb: ttr 125 plastics
    By Hunter_Lamb97 in forum Bikes and Parts Wanted - All Makes
    Last Post: 04-21-2016, 06:30 AM
  2. TTR 125 plastics
    By ccrosskno21 in forum Bigger Minis Forum
    Last Post: 03-16-2015, 08:51 PM
  3. Anyone have a set of TTR 125 08+ plastics?
    Last Post: 03-14-2015, 10:38 AM
  4. drz 125 klx 125 or ttr 125 pics
    By dupree in forum Bigger Minis Forum
    Last Post: 03-13-2012, 02:28 AM
  5. Newer Z plastics on an older Z
    By jupebag69 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 08-27-2006, 02:33 AM
