Inverted Fork Kit For Drz 125
This is a discussion on Inverted Fork Kit For Drz 125 within the Bigger Minis Forum forums, part of the General Talk category; Should get my 02 KX 85 forks next week sometime. Hope everything goes well. Need to figure out something with my rear shock though. I ...
Should get my 02 KX 85 forks next week sometime. Hope everything goes well. Need to figure out something with my rear shock though. I weight about 190 so I may have to go with the BBR spring. Just hope it isn't to stiff. I don't know of any others that make the spring. Do you guys? Thanks!
12-29-2006 07:37 PM
Looks killer! That chain guard needs to go though.
Hey overcash, glad youo found a pair of forks!! Good luck with it! I think the only problem your gonna have is the number plate mounting. Reall minor though!!
jgood, i need the chain guard
overcash, clear out your pms. I have green plastics ill trade you. i have a klx and am not a fan of the green.
chris
- You may not post replies
- You may not edit your posts
Forum Rules
drz 125 fork conversion
drz 125 fork guards
drz 125 forks
drz 125 front forks
drz 125 inverted forks
drz 125l fork conversion
drz125 fork conversion
fitting rm85 forks and suspension to drz125
inverted fork for suzuki drz125
kx 85 forks on drz 125l
rm 85 forks drz 125
what front forks will fit a 07 drz125
