shock spring question CRF100
This is a discussion on shock spring question CRF100 within the Bigger Minis Forum forums, part of the General Talk category; can i change the spring without changing the shock?...
Results 1 to 8 of 8
    bigliz34's Avatar
    Nov 2006
    RcWannabe's Avatar
    May 2006
    Erie, Pa
    Do u mean get a stiff spring for the stock shock, or mean switch the spring with out removing the shock?
    You can get # of different springs for the stock shock, I would personally go with the BBR unit. As for being able to not remove the shock you will need to remove it but it is a pretty simple job.
    Founder of the Fl Mullisha....Pa Chapter
    bigliz34's Avatar
    Nov 2006
    it says do not remove. what has to be done? thanks !!!
    i got a BBR spring wanted to throw it on with the stock shock
    RcWannabe's Avatar
    May 2006
    Erie, Pa
    Usually the BBR springs come with directions, I cant really give you advice cuz I haven't ever installed one on that particular bike. But if you have lost your directions call bbr and they can send you new ones by mail or email.
    fastestgirlaround's Avatar
    Jan 2007
    Ridgefield, CT
    you need to remove the shock...
    T1SBC1's Avatar
    Mar 2006
    Mass 508 area
    You Have To Compress The Spring Down ( You Will Need A Spring Compresor) To Remove The Retaining Clip. Then Off She Comes. Be Carful Putting The New One On. It Can Be Dangerous. It Was A Lot Easyier Buying The Works Shock And A Better Ride Too.
    THANKS TO BETTENCOURTS AND TORCO OILS
  7. #7
    Rubberducky's Avatar
    Oct 2005
    Winder Ga.
    In 04' when they changed to the crf vs. the xr they changed the shock. The spring retainer is welded in so you cant remove the spring. Not sure if they changed back in 05'-06'. But it is a whole different shock that they started using in 04' then from previous years. Take a pic and post it up. I would return the bbr and spend a few more hundred and get the works shock. Much better dampning.
  8. #8
    Rev Hard's Avatar
    Sep 2006
    Hawaii
    While, we are on this subject, i have a BBR spring for a XR/CRF100 for sale..let me know
bbr spring for 2007 crf100?
bbr springs crf100
crf100 shock install
how do you change a spring on a crf100
how do you put a sping on a crf100
how to change shock spring crf100
how to change spring on crf100
how to change the back spring on a crf100 2005
how to crf100 shock spring
mini bike springs crf100
my bbr crf100 spring is too stiff
single bbr fork spring crf 100 f
