WTB PWK28 angled for the XR100/CRF100 head
This is a discussion on WTB PWK28 angled for the XR100/CRF100 head within the Bikes and Parts Wanted - All Makes forums, part of the Classifieds category; like the title says looking for the angled like this http://www.minimobracing.com/store/p...duct_info.html Mini Mob is out and they say they have been back ordered for quite ...
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Like Tree1Likes
Thread: WTB PWK28 angled for the XR100/CRF100 head
    TeamIdeal's Avatar
    Jan 2015
    Mini Mob is out and they say they have been back ordered for quite a while.
    50race's Avatar
    Apr 2004
    North Vernon, IN
    I can try to order a new one $80 + actual shipping to you. Lead time will be a bit and a piece.
    TeamIdeal's Avatar
    Jan 2015
    well I'm not sure how long a bit and a piece is but I'd be willing to try that if you think it would be less than a month or so. if it would be over two months I'll probably just make my own.
    I just need to figure out the angle so I'm not making three or four before I get one right. it's one of those things you can buy cheaper than you can mess with.
    50race's Avatar
    Apr 2004
    North Vernon, IN
    I don't know the exact lead time :P. I'll order it. I'll keep it if it takes forever to come in.
    TeamIdeal's Avatar
    Jan 2015
    ok, keep me posted. I know two other guys that will be needing one so if you can get one I guess this will be a test run. thanks
    50race's Avatar
    Apr 2004
    North Vernon, IN
    FYI
    This Yoshimura manifold says it is in stock in Japan. Since the Kitaco manifold is proving to be hard to get building a custom Kitaco like manifold or trying this may be the only routes available.
    The cost of this retail is probably about $135. Little bit steep for just a small manifold but, I am considering it.
    It comes as part of this kit from Yoshimura which is $436 from Yosh. I think I could get them for ~$355 by shopping around a bit.
    Yoshimura TM-MJN26 Carburetor Kit 26mm XR100 MOTARD
    50race's Avatar
    Apr 2004
    North Vernon, IN
    I ordered one of these. It said in stock online. Did not know it existed until a few minutes ago. You may be the ginny pig to test fit this. All are designed for 26mm carbs . This Shift -up one is VM26 like the kitaco but this says billet compared to kitcao being cast and machined
    CABRATER KIT <---link to Shift-Up page
    May be the perfect Kitaco substitute.
    Retail ~$66 for the Shift-Up part here in the USA
    I'm trying to get one for myself as well. If you want to pay shipping you can test fit it with your setup and if it works buy it off me. If it doesn't fit send it back. Provided you post some pictures up on the forum
    sharky nrk's Avatar
    Feb 2015
    Good stuff.
  10. #9
    TeamIdeal's Avatar
    Jan 2015
    Quote Originally Posted by 50race View Post
    sounds like a plan to me. let me know when you have it and we'll get it headed my way.
  11. #10
    is Tinkering
    mrrcx's Avatar
    Jun 2011
    Westlake Village, CA
    I run one of these with a VM26, Not too familiar with the 28. just have to mind the choke setup on the 26 in my case.
  12. #11
    50race's Avatar
    Apr 2004
    North Vernon, IN
    On my 1982 twin shocker I notched the frame for the choke handle. It was a custom mani though. Cut the short tube out on a lathe and welded ears on it for the bolt holes.
  13. #12
    50race's Avatar
    Apr 2004
    North Vernon, IN
    Have the Shift-UP manifold in hand today PM me. :P Looks great.
ID:	207105Click image for larger version.
    I'm dont know if it will work for me becuase mine is so tight to the head now but may try one day...
ID:	207121Click image for larger version.
    TeamIdeal likes this.
  14. #13
    TeamIdeal's Avatar
    Jan 2015
    the Shift Up does not have the correct angle for the Tak head. I'm assuming it's for the stock head. if you mount it backwards the bores line up but the angle is completely wrong (last picture). even when you put it on the way it should be for the Tak head the angle isn't quite right and the bores do not line up at (pictures two and three). the first picture is of the setup I'm running now to get me by, if the Kitaco intake doesn't work I guess I'll be machining one myself. thanks for the effort.
ID:	207897Click image for larger version.
ID:	207905Click image for larger version.
ID:	207913Click image for larger version.
  15. #14
    50race's Avatar
    Apr 2004
    North Vernon, IN
    Now that I see you have a Tak +r head I can tell you that none of the manifold mentioned in this thread so far will work. Now that I see your pictures can also see you are working working on a conversion bike which none of the manifolds from japan are made for either. There are NSF manifolds that will point the card straighter back but it is not a guarantee that is will fit.
    link to some pics of the NSF100 tak +r intake kit
    http://www.takegawa.co.jp/pdf/03/03-05-0193.pdf
    Bad news is takegawa has discontinued this part
    minimob has them listed here. Do not know if they have them
    http://www.minimobracing.com/store/N...170/index.html
    CMS also lists them but unknown if they have them
    https://www.cmsnl.com/products/inlet.../#.WP2VUIjyuHs
    other listings
    http://global.rakuten.com/en/store/b...item/10098814/ mani kit
    http://global.rakuten.com/en/store/b...item/10100882/ mani only
    To be honest it looks like you will have to have a custom manifold.
    I think your carb would not reach the airbox boot even if it is pointes in the right direction with the NSF100 mani. Your intake runner length on your current setup is probably killing a few RPM :P
    Image of manifold on NSF100
    Hope that helps
  16. #15
    TeamIdeal's Avatar
    Jan 2015
    thanks for the links. Minimob is who told me the Kitaco would work. I will still buy it from you when it comes in. I will call them today and see if they have the NSF one. even if it's not quite right I should be able to modify it to fit. I can make an adapter for the rear to make the air boot and carb fit. my setup right now is definitely causing some upper RPM issues.
  1. WTB XR100 or CRF100 complete lower end
    By TeamIdeal in forum Bikes and Parts Wanted - All Makes
    Last Post: 03-09-2017, 06:21 PM
  2. wtb: crf100 xr100 parts: stock exhaust, wheels, clutch perch, seat
    By mad8vskillz in forum Bikes and Parts Wanted - All Makes
    Last Post: 06-25-2012, 10:05 AM
  3. xr100 angled spigot intake manifod
    By dougy in forum Vendor Area - Wanted
    Last Post: 08-10-2010, 07:31 PM
  4. WTB CRF100 - XR100 Complete Head
    By MikeeeP in forum Bikes and Parts Wanted - All Makes
    Last Post: 01-05-2010, 02:56 PM
  5. WTB XR100/CRF100 frame.
    By astroman in forum Bikes and Parts Wanted - All Makes
    Last Post: 01-07-2008, 09:33 PM
