Chain rubbing on swingarm
This is a discussion on Chain rubbing on swingarm within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; hey guys, i have a xtreme 107 with a five-O swinger. the problem is that the chain is at such an angle that it puts ...
Results 1 to 6 of 6
    theduck007's Avatar
    Mar 2009
    Fargo, ND
    hey guys, i have a xtreme 107 with a five-O swinger. the problem is that the chain is at such an angle that it puts alot of pressure on the swingarm where it bolts to the frame. i made a bracket and put a piece of plastic on there that was working ok, but i wanted to make it look nicer so i bought a little rubber piece to put on. it work for about an hour of riding and it cut it in half. so my question is what can i do about this. put a bigger sprocket on the front?? and back?? it has a 37 on back and like a 12 or thirteen on front. any input would help, thanks
    vetmxer's Avatar
    Feb 2006
    IOWA
    Re: Chain rubbing on swingarm
    put a 15 on the front. the 107 will pull it.
    vet
    DGA
    DGA is offline
    is finished second in the
    championship, woo hoo!
    DGA's Avatar
    Dec 2008
    Indianapolis, IN
    I put an 18 on the front of my SDG107 so first was a useable gear, and it pulls it great, and 4th is way fast now too, and it pulls pretty hard in that as well. Still hate the first/ second gear split, anone know of a taller first gear set that fits these Honda based engines?
    theduck007's Avatar
    Mar 2009
    Fargo, ND
    ok, i'll try some gearing, probably move both up a few teeth. and i found that other thread about the cutting board. i have snowmobile hyfax on there now and that works really good, just ugly. thanks
    is currently licking windows
    doopsx3's Avatar
    Aug 2008
    Yucca Valley
    Quote Originally Posted by DGA
    where did ya get the 18..I have a similar issue...runnin a 16 on my 107...38 rear..yeah 1st gear is not usable at all
    DGA
    DGA is offline
    DGA's Avatar
    Dec 2008
    Indianapolis, IN
    Ebay, item number 120385354316, was $12.50
chain rub swingarm
