i have a baja 50 i got for cheap from my friend and at first it wouldn't run off choke then now it wont idle at all. are both the jets in the carb on the baja 50 sapost to have a hole trough the middle because only the mane jet is a through hole and the little er jet is not a hole completely through. i tried to pit a little wire through the hole and it wouldent go throw. if i cant fix the carb im just gona get a stock 50 carb or sometin else
