Zongshen
This is a discussion on Zongshen within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Is their any upgrades i can do to a 125 zongshen motor...
Results 1 to 10 of 10
Thread: Zongshen
    pitbike11's Avatar
    Sep 2009
    Zongshen
    sdg1's Avatar
    Jul 2009
    Re: Zongshen
    i think thers a 140 kit on ebay and tbparts but not totally sure good luck man.
    rlm996's Avatar
    Apr 2008
    SWL Michigan
    Re: Zongshen
    ya, replace it with a good motor.........no offense.
    topr's Avatar
    Jun 2008
    Boise, Idaho
    Re: Zongshen
    Quote Originally Posted by rlm996
    your post is zero help and it sucked...no offense.
    topr's Avatar
    Jun 2008
    Boise, Idaho
    Re: Zongshen
    TB will have something. Take a look at some of the vendors listed on the main page. There are a few that will be able to suggest something. They may even chime in on this thread.
    rlm996's Avatar
    Apr 2008
    SWL Michigan
    Re: Zongshen
    Alright, fine. The Zongshen motor really responds well to porting. You don't have to do much to feel an improvement. Match your exhaust port opening to your pipe. Mine was alot smaller than the ID of my exhaust, and the ID of the exhaust gasket. You should be able to see a distinct line in your exhaust port where the gasket sets. This is kind of a guide for what to remove. Same with the intake. A little trickier there. Just use your intake runner gasket for the hole ID. Since the Zonger doesn't really have much poop in stock form, and revs very slowly you can install an IRK. These make the engine spin up faster. This is good and bad. Good because yo don't have to wait for ever for the thing to rev up, bad because it tends to explode clutches (my son has blown 2 this summer). Another fairly easy upgrade is a cam. Do some research as to which one to use. I bought one from DRATV and did not like it. I think there may have been something else going on at the time though. I just never gave it another chance. Valve clearance is a big deal on this motor. Don't get them too tight. It will run even worse, and start hard. 4 to 5 thousandths is good. I even let them clatter a little. I haven't done this but a High comp piston would really wake it up also. Stock, I can start it with my hand....
    Maybe this is more of the answer you were looking for TOPR?
  7. #7
    pitbike11's Avatar
    Sep 2009
    Re: Zongshen
    thanks
  8. #8
    rlm996's Avatar
    Apr 2008
    SWL Michigan
    Re: Zongshen
    But then again by the time you do all this you will still not have as good of a motor as if you just saved up and bought a better one.....
  9. #9
    pitbike11's Avatar
    Sep 2009
    Re: Zongshen
    which motor do u recomend
  10. #10
    rlm996's Avatar
    Apr 2008
    SWL Michigan
    Re: Zongshen
    I honestly don't think it would matter. Any 140, or 150 main shaft motor would be great.
    Check this thread out.
    http://www.planetminis.com/f17/140cc...-a-132720.html
    That 150 is bad a$$!!
upgraded cam for 140 zongshen
what exhaust port is a zongshen 125
zongshen clutch remove
zongsheng 140
