what carb is this?
This is a discussion on what carb is this? within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Just wondering what carb this is? is it a true mikuni? I have it on a lifan 150cc would there be something better that i ...
Results 1 to 6 of 6
    dustnuts27's Avatar
    Jun 2008
    Menomonie, Wi
    what carb is this?
    Just wondering what carb this is? is it a true mikuni? I have it on a lifan 150cc would there be something better that i could be running. Would the mikuni vm26 from trail bikes be better. Or would a flat slide carb be worth the money? Any other options? Thanks
    vetmxer's Avatar
    Feb 2006
    IOWA
    Re: what carb is this?
    Looks like a 22mm mikuni but I have never seen a genuine mikuni with a choke like that.
    vet
    is just truckin' along...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Appears to be the 22mm Mikuni-clone that has come standard on quite a few of the Chinese pitbikes. It seems to be missing the plastic part of the choke lever.
    Here is a picture of an authentic VM22 Mikuni carb...
    - dirtbkr188 -
    is Not liking the new PM
    Blackwoodz's Avatar
    Aug 2008
    SC Michigan
    Its not the same as the 22mm Mikuni clones....looks more like the 28-30mm clone to me.
    It has the butter-fly choke.
    is Eat - Sleep - Work - Live -
    PIT BIKE !
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    its actually a china carb
    its larger than the normal china 22mm mikunis were use to seeing (poss 26mm)
    it takes the same rs / hs type jets , runs good and its nice because its a flange mount
    i have one on a bike we use for testing and it runs clean
    just never listed then online store yet
    T Bolt USA - Let's go riding!
    Online Store - Tech Database - Facebook - TheCRKid@TBoltUSA.com - (704) T-BOLT-US - Skype: TBoltUSA
    dustnuts27's Avatar
    Jun 2008
    Menomonie, Wi
    thanks for the help guys... glad to hear its a 26mm i wasnt sure about that i'll pry just run this on for awhile seems to work pretty good... the problem i have is my heat stop cracked i must have tightened it to much the last time i took the carb off T Bolt think you could hook me up with a new one thanks
22mm mikuni carburetor choke lever
22mm mikuni choke
mikuni rs 22 clone
planet minis
