engine upgrade questions
This is a discussion on engine upgrade questions within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; What are some cheap upgrades I can do to my yx150? I have a Kitaco inner rotor, Kitaco super coil, and Mikuni tm28 carb. Can ...
What are some cheap upgrades I can do to my yx150? I have a Kitaco inner rotor, Kitaco super coil, and Mikuni tm28 carb. Can I get more power from a takegawa cam over the stock? I think that I can only go with a big bore kit and aftermarket head now right?
09-21-2009 12:00 PM
Re: engine upgrade questions
Do you have the KLX head style yx 150? If so you can do the V2 head or the tb184 bore. A few customers have gone bore only and head only and have been very happy....then later you can add the other.
If you have the lifan BVH style yx 150, you can do the TB import race head...and/or a 160 bore kit.
Everything is here:
TB upgrade parts
the Daytona type is a DTE-5 , thats the manufactures model designation
I have the klx110 style head and cylinder. So then I can only go with the big dollar items now? Bummer.
What about a different cam though?
I have a good 160 crank for that motor...take it from a 53mm stroke to a 57mm stroke... cheaper than a cam or BBK..
Originally Posted by
blackwoodz
i have a good 160 crank for that motor...take it from a 53mm stroke to a 57mm stroke... Cheaper than a cam or bbk..
wow that would be sweet
For how much? If I did that I could then put all new ceramic bearings and have the crank balanced and knife the edges! Man I am all ready to try this. Does anybody know if you can upgrade the clutch cover to the daytona style?
You can add ceramic bearings and all that to the 150 crank if you want to spend more on bearings than the engines worth...
I will take $70 shipped for the crank(only ran it about 2hours tops)....and you need a slingerless crank for the daytona..covers and even then it needs modded to work....also good luck finding those covers forsale...I only know one guy that can get them...and he builds big bore motors with them........
BTW the cranks comes with a steel slinger that has been turned and trued to match the crank.
throw a used r head on it!! thats wat i'm runing and it pulls!!!
Isn't firepower the one who uses the clutch cover? The ceramic bearing are that exspensive?
- You may not post replies
- You may not edit your posts
Forum Rules
