How do I jet my MOLKT?
This is a discussion on How do I jet my MOLKT? within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; So I have a MOLKT 26mm carb on my YX140. When the clip on the needle is set in the middle groove it wont idle ...
Results 1 to 8 of 8
    mx4lifeCR125's Avatar
    Sep 2008
    Crystal Lake, Illinois
    So I have a MOLKT 26mm carb on my YX140. When the clip on the needle is set in the middle groove it wont idle but it feels and sounds right after you touch the throttle. The higher you set it the better it idles but then dies when you give it gas. What jets and in what direction should I jet it?
    Thanks!
    SCAR8's Avatar
    Oct 2006
    Springfield Mo.
    Re: How do I jet my MOLKT?
    Throw it in the trash and buy a Mikuni VM26 thats how I'm going to jet mine! lol Contact Matt at pitster and they can get you some jets to make it run pretty good!!
    SCHMEEL's Avatar
    May 2005
    COESSE, INDIANA
    start with a 25 pilot jet. thats were i started
    PitBIKE & DESTROY
    OneEyeRacing "killer clownbike style"
    Sep 2008
    Hey, thanks. I can just pick those up at Pitster?
    And ya, I would throw that thing away but I have a very low budget... Like, $10.
    schofell84's Avatar
    Feb 2007
    Ogdensburg
    sounds like you have the idle fuel screw tightened in?
    midwest_militia's Avatar
    Nov 2007
    Ottawa, IL
    The best I can get it is 25 pilot and 120 main (I have bigger motor and V2 head so you may have to go leaner on the main). Air screw about 3/4 - 1 1/4 turn out and the needle 2nd from the bottom with a small shim to let it sit between the bottom and 2nd to bottom clip. I also raised the floats quote of bit.
    Hope this helps! This got me by but I have a PWK 28 on the way from Tbolt.
  7. #7
    mspike's Avatar
    Jul 2007
    P-town Indiana
    I have the same set up as you and I use a 25 pilot and 115 main I think and it runs great. You may have to adjust the floats though if it bogs after jumping.
  8. #8
    kawasakicoby125's Avatar
    Jul 2008
    Lynnwood, WA
    i have a tb28 ill sell u for CHEAP!
molkt jett
