Oil Leak
This is a discussion on Oil Leak within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; The other day I put on a new clutch with an impact wrench....Is it possible that I tightened it too much that now oil leaks ...
Oil Leak
The other day I put on a new clutch with an impact wrench....Is it possible that I tightened it too much that now oil leaks out of the clutch adjustment cover on the other side (Orion 29 Pro)? Is there some sort of seal /gasket that I may have messed up when I tightened the clutch that would make it leak?
Any help would be appreciated!
10-07-2009 09:46 AM
Re: Oil Leak
can you put pics up that mite help...wat motor do you have?
Re: Oil Leak
I posted pics a little while back...If you search under "Forks for Orion / Apollo" You will see them....under BigPapa
Thanks for your help....
- You may not post replies
- You may not edit your posts
Forum Rules
