Lifan 125 mods? v. noob
This is a discussion on Lifan 125 mods? v. noob within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Alright, so I have a Lifan 125, and of course, I want to mod it. I have a Pro Circuit T4 on the way, and ...
Results 1 to 9 of 9
    fazle's Avatar
    Jul 2008
    I have a Pro Circuit T4 on the way, and I want to get some more top end power and some more over-rev. I know that a cam is the answer, but which one? I found one that looks like it might work, a Hot Cams Stage 2. Will this be a step up?
    My concern is that most parts are designed for 50 and 88cc engines, not chinese 125's.
    Any help would be greatly appreciated.
    chaddy721's Avatar
    Aug 2008
    Leeper,Pa
    Re: Lifan 125 mods? v. noob
    i puta 160 bbk with 28mm carb and big valve head on mine 125..it rips! get any import cam.....
    Banned
    firepower354's Avatar
    Oct 2006
    Flint MI
    It depends... There are several different Lifan 125's, some more suited to performance builds than others. Trans? Clutch? Head?
    cdoublejj's Avatar
    Oct 2008
    USA, MO
    CARB! remember they come under carbed with the puny 28mm knock off's that they pass off as 20mm
    fazle's Avatar
    Jul 2008
    Well, I'm limited to 125cc's, so going bigger is out. As for the head, clutch, etc. I have no idea. The trans is 1d3u. Are there any identifying marks I should be looking for?
    Banned
    Oct 2006
    Flint MI
    Pics would be fastest. Valve caps screw in or have two bolts?
    Clutch arm in the front, or top rear of the clutch cover?
    cdoublejj's Avatar
    Oct 2008
    USA, MO
    Quote Originally Posted by fazle
    no no the carb, the carb is to small you need a bigger carb to let more air in the combustion chamber other wise your wasting money on a cam casue you can't feed it enough gas and air, i have made this mistake my self.
    fazle's Avatar
    Jul 2008
    Quote Originally Posted by firepower354
    Valve caps, idk off hand, clutch arm is on top.
    I'll post pics tomorrow.
  10. #9
    fazle's Avatar
    Jul 2008
    Quote Originally Posted by cdoublejj
    Got what you were saying, Chaddy said something about a 160 bbk.
    I already put a bigger carb on it, a $40 ebay special, but it helped soo much, but it's still chinese crapperware. I was looking @ a 28mm Mikuni, but $300+ is a bit steep right now. FML
lifan 125 best mods
lifan 125 engine mods
lifan 125 modifications
lifan 125 mods
lifan 125 performance
lifan 125 upgrades
lifan 125cc modified
lifan 125cc mods
lifan 125cc upgrades
lifan mods
lifan performance mods
modified lifan 125cc
