tb cdi/rev box wiring
This is a discussion on tb cdi/rev box wiring within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; I have a OGM with a yx 150. I got a tb cdi from t bolt and I got the adapter wiring harness. Turns out ...
Results 1 to 4 of 4
    tatra813's Avatar
    Nov 2010
    I have a OGM with a yx 150. I got a tb cdi from t bolt and I got the adapter wiring harness. Turns out my cdi unit (stock) doesnt have a wiring harness just 5 wires that come off and run to different spots. I want to cut off the plug and wire into the correct spots.
    My question is does anyone have a wiring diagram or know on a tb box which pins?wires go to what?
    Thanks
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    Re: tb cdi/rev box wiring
    Sounds like you have an inner rotor kit ignition
    Pull your ignition cover off and reference the ignition type
    TB CDI is only for Flywheel type ignitions
    T Bolt USA - Let's go riding!
    tatra813's Avatar
    Nov 2010
    Quote Originally Posted by T Bolt USA
    Is there a aftermarket cdi box that will fit my setup. I believe you are correct. Trying to get rid of the rev limiter.
    kg70's Avatar
    Jan 2010
    U.K Wales
    ive just changed my lxr to the tb cdi and ive had to change the whole electrics to a yx rotor and loom to go with it cost my £90 all in including rotor, rev box ,adaptor, loom, delivered for that price
cdi adapter harness
cdi box wiring
chinese cdi box wiring
chinese cdi box wiring diagram
tb box diagram
tb cdi
tb cdi box wire harness
tb cdi pinout
the pins on tb cdi
which wires go where on a chinese cdi
wiring stock cdi to inner rotor
yx 150 wiring diagram
