Cg 200 Stator Wires
Cg 200 Stator Wires
This is a discussion on Cg 200 Stator Wires within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Hi all happy new year, I have have read a lot of helpfull post on this matter already bvut still have a problem,on my engine ...
Results 1 to 5 of 5
    alex22's Avatar
    Nov 2009
    I have have read a lot of helpfull post on this matter already bvut still have a problem,on my engine there is two yellow wires insted of the usual yellow&white or yellow&pink
    for the charging and litting circuts,how can i tell whitch is whitch ???can i do an ohms test to find out.
    Any help thanks
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    the 2 yellow wire type is normally both ends of the same coil
    you will get continuity ready thru you meter
    http://tboltusa.com/store/tech.php?p...ng+With+Lights
    T Bolt USA - Let's go riding!
    alex22's Avatar
    Nov 2009
    Quote Originally Posted by T Bolt USA View Post
    Thanks for your prompt reply,that might explan why i keep blowing rectifiers and have cooked my battery,i had a look at the diagram you sent,but istill cant see how i can get this type of stator to charge my battery,do i earth one of the yellow wires,and what type of rectifier/regulator do i need to use for this to work properly,most reg/rectifier i have tried have 4 wires.
    mmooonlyter's Avatar
    Mar 2009
    If your stator has a floating ground, you can use the trail tech reg/rec and connect the yellow wires and run a full dc electrical system. You can check by checking for continuity between the yellow wires and the engine case, if none the stator has a floating ground.
    alex22's Avatar
    Nov 2009
    Quote Originally Posted by mmooonlyter View Post
    Just what i was looking for great info
    Thanks again.
200 cc stat?r reg?lat?r
cg 200
cg 200cc stator regaler
cg200 engine diagram
cg200 engine wiring diagram
cg200 wiring diagrams
cheap cg200 stator
chinese+cg200+wiring diagram
continuity between wires stator
how to test if a stator has a floating ground
yx cg 200 wiring diagram
yx cg200 wiring parts diagram
