sdg help!!!!! jetting and others .. new to this pics to help
This is a discussion on sdg help!!!!! jetting and others .. new to this pics to help within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; ok .. well here it is .. i have purchased a 2005 sdg speed mini butt it has the sdg pro 125 motor .. cylinder ...
Foam air filters are to be oiled , ALWAYS
Engine and Carb quick check list - TBolt USA Tech Database!
1)Install Intake manifold to head and carb, oil gaskets and tighten bolts lightly at first then torque then down gradually in a cross pattern to provide a good seal and avoid air leaks
2)Make sure the carb is 100% clean, free of debris and you can see light thru both main and pilot jets
3)Double check you valve tappet adjustment .003intake and .004exh.
4)Make sure your exhaust gasket is installed properly.
5)Make sure all electrical connections are tight and you have a solid ground from the engine to the frame.
6)Check for good fuel flow and fresh fuel.
7)See our jetting guide and do a plug read.
http://www.tboltusa.com/store/tech.php?pid=61
The 107 might be a size too big, but the 20 pilot is too small, go to at least a 22.5 or better a 25 pilot. Low needle is to compensate for the rich main jet but it really doesen't work that way.
Originally Posted by
DGA
ok i might have worded that wrong on the needle part for you guys .. i ment i rised the needle lowered the clip .. in other words made the needle to the richest position .. and valves are good fresh gas fresh plug.. and if i move my fuel screw out more my idle dropps and gets lumpy .. while at 1 and half turns out its smooth and crisp idle ..
T Bolt USA
Protip: Get a thin wire brush. Break a wire off. Run it THROUGH the pinholes in each jet! a SPEC of dirt can ruin your whole day. Then use a air compressor, a straw, your dog.. Find something to blow air throw with high pressure to make sure the dirt gets out. Make sure there's a WHITE towel underneath to see if something comes out, has helped me before!
I'm one hell of a typer. Maybe it helps with throttle control?
Visit the
Typing Test and try!
TheStock50Kid
i did this .. ive checked it all .. its not and issue of that its jetting .. i know it is .. its got a whole different carb then whats saposed to be on there seeing sdg told me it comes stock with a 20mm and i have a 22mm .. i let the carb and jets sit in carb cleaner over night .. and use wire and 70 psi of air ran threw them jets and cleaned petcock and rechecked gaskets no air leaks .. i sprayed carb cleaner all over while the bike was running and idle didnt drop nor get higher .. so its sealed .. and my filter had oil and it did the same with oil i just cleaned it and ran it without oil to see if it made a difference and nothing .. problem is theses carbs choke only choke pilot circuit not the whole intake side so i can run the chocke to see if my top end or mid range is lean .. the chokes diferent then the ones on the kehin carbs im usto .. and plug chops outta question seeing its different everytime i try it .. im in rhode island usa so dont know my sea level or whatever i never use that to jet i use how my bikes run and whats into them to rejet .. im stummped .. check electricals even key switch getting good spark .. dont get it ,,, its either lean or rich .. i just dont wana get jetts and bounce all around .. just wondering if anyone has a good set up for this motor .. its stock sdg exhaust ... as for motor work i have no clue .. could have a higher comp piston could not could have a cam who knows without opening the motor .. and im not doing that to do jetting ..
THANKs for all advice u guys are giving im greatfull for the time u take .. butt im still att a dead end .. ok on my carb is turning my screw out counter clock wise giving me more fuel .. and turning in gives me less fuel .. .. i knows theres a fuel screw and a air screw .. mine is on the motor side under the carb not on the side of the motor by the filter .. .. if i turn it out to about 3 or 4 turns out idle dropps and gets lumpy .. if i bring it out 1 turn to 1 and a half turns its smooth and crisp .. so seems as thou maybe its dead on or maybe a sixe higher on my pilot would be good .. and again 107.5 main jet and im at the last needle clip position available witch is the richest spot for the needle
Hey 50kid, running wire through jets is NOT a protip! Never poke wire through jets, you can scratch the bore and the tapered inlets that way. Just use solvent and a compressor blast.
[QUOTE=DGA;1756416]Hey 50kid, running wire through jets is NOT a protip! Never poke wire through jets, you can scratch the bore and the tapered inlets that way. Just use solvent and a compressor blast.
TRUE STORY .. butt i even tryed that method and ruled out my jettings off plain and simple
- You may not post replies
- You may not edit your posts
Forum Rules
By 2001kx in forum Chinese/Import Minis - General Discussion
Last Post: 06-14-2010, 10:23 PM
By MxRider110 in forum Roost Area
Last Post: 04-24-2008, 08:40 AM
By AndRenner in forum CRF50
Last Post: 11-21-2006, 07:32 AM
Last Post: 11-20-2006, 04:41 PM
By crf50kid in forum CRF50
Last Post: 04-14-2005, 12:04 PM
2006 pitster pro 125 carb jetting
mikuni 22mm taper bore jetting on chinese 110
sdg 107 main jet
sdg pro mini 107 gas out of air filter
sdg speed mini jetting
what is clip in jetting pics
Tags for this Thread
