Apollo ABG37 Clueless
This is a discussion on Apollo ABG37 Clueless within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; I have a apollo abg37 (crf70 ) and the thing keeps bogging out when I twist the throttle, I've cleaned the carb and cleaned every ...
Results 1 to 14 of 14
    KyleNeary's Avatar
    Jan 2012
    atlanta,ga
    I have a apollo abg37 (crf70 ) and the thing keeps bogging out when I twist the throttle, I've cleaned the carb and cleaned every gas passage and still bogs I have no idea what it could be.
    Any thoughts?
    DGA
    DGA is offline
    is Got a third place in my first
    event
    DGA's Avatar
    Dec 2008
    Indianapolis, IN
    Has it always done this or did it just start to run that way recently?
    KyleNeary's Avatar
    Jan 2012
    atlanta,ga
    No it didn't just started this week had t side Christmas
    is BRAAAAAAAAAP !!!!
    Ebrown's Avatar
    Feb 2008
    Clarkston, MI
    check your timing. maybe you spun the flywheel key?
    is Looking for Takegawa special
    clutch and CR 3speed for crf50
    davmo's Avatar
    Dec 2011
    Denton Texas little d.
    Quote Originally Posted by KyleNeary View Post
    Any thoughts?
    Have had a similar problem due to bad gas flow from the tank. Just enough gas was getting in to get an idle, but any more than that, and it would bog out.
    Check to see that gas is filling the carb bowl.
    KyleNeary's Avatar
    Jan 2012
    atlanta,ga
    Got a new bigger carb it solved my problem
  7. #7
    DGA
    DGA is offline
    event
    DGA's Avatar
    Dec 2008
    Indianapolis, IN
    This practice of replacing parts, spending money to fix things is why people are losing the ability to fix things.
    Bogging out, not easy to get much off that, but, it still sounds like it is the carb, odds of the flywheel shearing the key are slim to none if nobody has messed with that part. Pull the carb apart again, pull the jets out and make sure you can see light through all the ports in the carb, and blast compressed air though it. Check the float level, the floats should be level when you turn the carb upside down and look at them.
  8. #8
    is Ride this
    geezer's Avatar
    Dec 2009
    Blackwood N.J.
    Alot of china carbs ARE junk. Its not like youre cleaning a Jap Mikuni. Yes flyweel keys DO sheer. Ive seen a few new motors that i have built have loose flyweel nuts from the factory.
    Ride on the edge
  9. #9
    DGA
    DGA is offline
    event
    DGA's Avatar
    Dec 2008
    Indianapolis, IN
    Well OK. Pull the left sidecover off and check that the flywheel nut is tight first, easy enough to do. But he said it WAS running ok and started 'bogging', so the carb, whether it was made in china or timbucktoo, it WAS working before, so look to see what is different there before buying another and having to jet that.
  10. #10
    KyleNeary's Avatar
    Jan 2012
    atlanta,ga
    The carb that came on the bike u couldn't take the float bowl off it was weird so we couldn't even clean it so I went a d bought a whole new carb and it runs better than before
  11. #11
    DGA
    DGA is offline
    event
    DGA's Avatar
    Dec 2008
    Indianapolis, IN
    See, this is why people have trouble getting help here, you said "I've cleaned the carb and cleaned every gas passage", but now you say you couldnt get the bowl off? Sigh...
  12. #12
    is Ride this
    geezer's Avatar
    Dec 2009
    Blackwood N.J.
    Quote Originally Posted by DGA View Post
    I see youre point.
    Ride on the edge
  13. #13
    Ebrown's Avatar
    Feb 2008
    Clarkston, MI
    just because the flyweell nut is tight doesnt say much. you need to make sure the timing is correct. the flyweell has a magnet on it that hits the magneto. when they are lined up the mark on the case needs to be in line with the stamped letters on the flywheel. if this looks good, then you need to check your valves. make sure you have clearence, also make sure they are not sticking. open or closed. keep us posted
  14. #14
    KyleNeary's Avatar
    Jan 2012
    atlanta,ga
    It was a carb issue the carb on the bike was built as one piece, it was a jinke carb so bought a new carb on the bike and runs great
  1. Apollo Orion AGB 29 $700 obo
    By MeanMini125 in forum Complete Bikes For Sale - All makes and models
    Last Post: 10-16-2009, 03:50 PM
  2. Opinion on Apollo agb 29
    By MeanMini125 in forum Chinese/Import Minis - General Discussion
    Last Post: 10-14-2009, 09:48 PM
  3. Car audio? I'm clueless...
    By Racinguy542 in forum Off Topic
    Last Post: 07-31-2008, 09:47 PM
  4. QA50 Spark Problems - Clueless!
    By Potterfx4 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 06-16-2008, 07:24 PM
  5. Apollo pitbikes ???
    By horde in forum Chinese/Import Minis - General Discussion
    Last Post: 08-09-2006, 10:06 AM
apollo 2009 agb 37
apollo ag 37 pit bike
apollo agb 37
apollo agb 37 carb adjustments
apollo agb 37 gas tank
jinke carburetor
jinke carburetor settings
jinke carburetor tuning
jinke carburettor copy of
jinke carby tuning
junk motor planetminis
what is a jinke carbeurator
