Suspension Adjustments SSR
This is a discussion on Suspension Adjustments SSR within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Hey whats up all. Looking to get some pointers. Keep in mind this is for tooling around riding, and an occasional wheelie or two. No ...
Results 1 to 2 of 2
    SO-FLO's Avatar
    Mar 2012
    Hey whats up all. Looking to get some pointers. Keep in mind this is for tooling around riding, and an occasional wheelie or two. No uphill triples.
    Pre Load adjustment... (retainer and locker on cheap suspension) on base model SSR125
    1) Would a softer pre load, raise or lower the ride height?
    2) Would a softer pre load in increase or decrease the potential stroke length
    I ask because I am a heavier taller guy than average, 6'2 200, and I want a stiffer ride but don't want to sacrifice ride height for stiffness. (long legs)
    Also, I noticed my fork tube caps are flush with the triple clamp. What is the easiest way to get those forks about 1/2 inch above the clamp.
    Thank you for the replies.
    SO-FLO's Avatar
    Mar 2012
    BUMP
    Wanna work on it when I get home from "ze werk"
  1. fork adjustments , help!!
    By tolgatt in forum CRF50
    Last Post: 08-04-2009, 07:23 PM
  2. 07 x4 fork adjustments?
    By nettyspeghetti in forum Chinese/Import Minis - General Discussion
    Last Post: 07-27-2009, 08:54 PM
  3. valve adjustments
    By crf50luke in forum CRF50
    Last Post: 01-28-2009, 11:44 AM
  4. Hot Valve adjustments
    By mo-tarded in forum KLX110, DRZ110, TTR90
    Last Post: 10-12-2008, 09:31 AM
  5. GPX motor adjustments!
    By coleuden in forum Chinese/Import Minis - General Discussion
    Last Post: 12-18-2006, 08:04 AM
adjusting ssr front suspension
how to rise the supension for the ssr70
increase ssr 125 ride height
ssr 125 rear shock
ssr 125 rear shock adjustment
ssr 125 replacement rear shock
ssr 70 fork failure
ssr 70 suspension
ssr rear shock adjustment
ssr suspension
tighten ssr 125 front suspension
whole front of a ssr 70 suspension
Tags for this Thread
