Yx150 burning oil
Yx150 burning oil
This is a discussion on Yx150 burning oil within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; I have a pitster x4r with the yx150 from 2007 and it's bored to a 160 but other then that it's stock. I was having ...
Results 1 to 2 of 2
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    Yx150 burning oil
    I have a pitster x4r with the yx150 from 2007 and it's bored to a 160 but other then that it's stock. I was having problems with it burning oil and I was told to put valve seals in it so I did and I am pritty sher every thing is running good and stuff no nicking or nocking so every things good. It burns what looks like blue smoke and when I took the head off a turn the motor over and the cylinder didn't look scared up or burnt and u could still see the marks from the machining from the factory and it has good compression and it smokes when cold then kind of goes away but u can still smell the oil burning. I already fixed the kinked case breather and it probly only has 60 hrs on the bore kit do let me no what u think and thanks.
    to live is to die, but die on a bike
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    I no I have posted some other things about the burning oil and my motor but I think I am going to be getting new rings and piston and stuff so hope it will be good after that I already got the new valve seals in so hope the rings work because It only smokes when it's cold but u can still smell the oil when warm
  1. Burning oil need help!!!
    By PitsterFreak in forum Chinese/Import Minis - General Discussion
    Last Post: 04-20-2010, 12:10 PM
  2. Burning oil need help!!!
    By PitsterFreak in forum Pitster Pro
    Last Post: 04-19-2010, 10:27 AM
  3. burning oil
    By drz143 in forum KLX110, DRZ110, TTR90
    Last Post: 06-09-2009, 02:00 PM
  4. 03 xr 50 burning oil
    By fred88gt in forum CRF50
    Last Post: 03-17-2009, 07:43 PM
  5. burning oil?
    By woodsracer in forum CRF50
    Last Post: 09-18-2005, 08:51 PM
oil for yx150
pitster pro 150 smoking
pitster pro burning oil
pitster pro burns alot of oil
pitster x4 valve seal
what oil for yx150
yx 150 valve seals
yx 150 valves
yx 160 burning oil
yx150 burning oil when cold
yx150 engine smoking when warm
yx160 burning oil
