124cm3 engine
This is a discussion on 124cm3 engine within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; My bike came with a Loncin 124cc engine, clutch off crank. It is all black and has CDI on the cam cover. It says PL-4 ...
Results 1 to 1 of 1
Thread: 124cm3 engine
    bulkytits's Avatar
    Nov 2005
    124cm3 engine
    My bike came with a Loncin 124cc engine, clutch off crank. It is all black and has CDI on the cam cover. It says PL-4 on the side of the cylinder along with 124cm3 does anyone have any idea what bore and stroke this motor is and what size the valves are in the head? it has the oil plate with the short lobe on it so i assume it takes the long lifan cam dr atv carries.
    I was hoping that it had a big valve head on it so i could use it on my (hopefully ordering this week) gpx motor
    just wondering cause i dont want to pull the motor apart to check if i dont have to
    thanks
Remove Ads
124 cm 3
124 cm3
124cm2 dirtbike engine
124cm3
124cm3 atv
124cm3 engine
pl-4 124cm
pl-4 124cm dirt bike engine
pl-4 124cm3
pl-5 124 cm 4 stroke
pl-5 124cm
what motor is a 124 cm dirt bike motor
