internals of the daytona anima revealed for the first time
This is a discussion on internals of the daytona anima revealed for the first time within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; recently purchased one of these anima 150s and just couldn't help to tear into it. here are some pics for you other builders that have ...
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 39
Like Tree1Likes
Thread: internals of the daytona anima revealed for the first time
    storminnorman07's Avatar
    Nov 2005
    new castle, pa
    recently purchased one of these anima 150s and just couldn't help to tear into it. here are some pics for you other builders that have been pondering on the engine
    anima primary on bottom yx on top
    stud pattern difference
    squirt
    Nov 2005
    new castle, pa
    dyno of the 150
    Nov 2005
    new castle, pa
    intake valve job
    full view of intake valves
    not thrilled w/ factory valve cut location
    exhaust valves
    exhaust seating width and location isn't all too too bad
    exhaust seat cuts
    valve springs and retainers, retainers are steel
    cam and rocker arms
    i thought this was neat. daytona knocked 4 holes in cam sprocket 2 holes for the moron proof cam timing and 2 slotted for the engine builders that like to degree their engine
    exhaust port
    super easy to access and work on valve train
    intake port, def room for improvement
    SwapperMX's Avatar
    Sep 2009
    So ...... overall opinion of this new engine ?? Rating out of 10 ???
    is wishing the garage was warmer
    so I can get some stuff done.
    tblumer's Avatar
    Mar 2009
    Upstate NY
    ka-Pow! Thanks for sharing. Whats the weight on that thing? My YX is heavy, the pics of the anima give me a "boat anchor" vibe.
    taz69's Avatar
    Nov 2005
    LOOKS like a Honda Wave stud spaceing. Get a bigger crank and a 150R piston and you have a 190. IM guessing piston pin height is 14mm?
  7. #7
    is going hard
    JanssonK's Avatar
    Jun 2009
    Sweden
    How is the engagement in the gearbox? have never had any problems with the teeth, but the gears doesn't engage enough and slip
  8. #8
    BlackBeard's Avatar
    Oct 2007
    50 riders
    Thanks for the pics, lovin the sticker!
  9. #9
    Vim
    Vim is offline
    is If ifs and ans were pots and
    pans, there’d be no
    trade for tinkers.
    Vim's Avatar
    Jun 2008
    Russian Federation
    Truly, first normal inside overall look. Thanks! I look forward to How-to's to finalize the D4V engine.
  10. #10
    is Going big or going home!
    Jordo's Avatar
    May 2012
    LancasterPA
    Why did you take a new motor apart? Do you make parts for this motor? Or are you a speed shop, and you port, grind cams, and so on?
  11. #11
    Nov 2005
    new castle, pa
    Quote Originally Posted by SwapperMX View Post
    my overall opinion is it has alot of potential but it is still a ching engine and shows all the tale tale signs of china, time will tell if my suspsions on certain things will become a reality or just over worring. casting and machineing isn't as nice as you would see on the jdm stuff. but for what you pay vs what you get i think its best china setup by far. i'm not going to give it a rating until i have beat on it a while.
  12. #12
    Nov 2005
    new castle, pa
    Quote Originally Posted by tblumer View Post
    she has some weight on those hips about 47~48lbs
  13. #13
    Nov 2005
    new castle, pa
    Quote Originally Posted by taz69 View Post
    haven't messed w/ many waves so i'd be lying if i said it was the same spacing. with daytonas bigger stroke crank and 150r piston it will put you over 190cc. anima 150 is 62mm x 49.5mm = 149.44mm crf 150R 66mm x 43.7mm= 149.51cc utilizing the anima's 49.5mm stroke w/ the 150r piston putting bore and stroke at 66 x 49.5= 169.35cc. i havent checked to see what daytona 190 stroke is but i'm going to guess prolly 62-62.7 which would put cc in the ball park of 213~214 w/ 150R piston.
    wrist pin is 14mm comp height is 20mm or for the pitbike community 13mm
  14. #14
    Nov 2005
    new castle, pa
    Quote Originally Posted by JanssonK View Post
    not quite sure what your asking, how does it engage?
  15. #15
    Nov 2005
    new castle, pa
    Quote Originally Posted by BlackBeard View Post
    haha gotta show some love to the forbidden one
    Special~K likes this.
  16. #16
    Nov 2005
    new castle, pa
    Quote Originally Posted by Jordo View Post
    why not take a new engine apart? i guess you'd call me a half ass speed shop. i don't advertise or do it full time but in my spare time i build engines for guys and race teams. i have had alot of guys ask me whe i could do w/ this engine. and until now i have not been able to give an honest answer cause i haven't been into one. so to answer your orginal question i tore apart to see what i'm working w/
  17. #17
    is going hard
    JanssonK's Avatar
    Jun 2009
    Sweden
    ehm like this Click image for larger version.
  18. #18
    Jordo's Avatar
    May 2012
    LancasterPA
    Quote Originally Posted by storminnorman07 View Post
    I believe he is asking about the dogs on the gears. Older China stuff didn't have enough back cut or IMO the gear and dog were too soft. The dogs would round off and cause it to pop out of gear, or not engage at all.
    Ahh, I see. Well knowing is half the battle !
  19. #19
    sm00th's Avatar
    Feb 2012
    Wossner have 66,68& 70mm pistons for the 150r with 20.6mm comp height The 190 anima is 62mm stroke. Any chance of cc the head?
  20. #20
    sm00th's Avatar
    Feb 2012
    Vertex also do a 72mm piston. With the 62mm stroke it would be just over 250cc. What is the OD of the stock sleeve?
  1. Daytona Anima 150cc 4 Valve Engine in stock T Bolt USA
    By T Bolt USA in forum T-Bolt USA
    Last Post: 08-09-2012, 09:50 AM
  2. Daytona Anima 190f 4v
    By Mr Tarded Mo in forum Chinese/Import Minis - General Discussion
    Last Post: 05-17-2012, 03:21 PM
  3. Testing Daytona Anima 150F
    Last Post: 05-04-2012, 04:41 AM
  4. Replies: 37
    Last Post: 03-31-2012, 11:07 PM
  5. Daytona Anima 150cc 4 Valve Eng
    By 50race in forum Roost Area
    Last Post: 03-04-2012, 04:10 PM
anima daytona 190cc engines
daytona 190 anima
daytona anima
daytona anima 150f
daytona anima 190
daytona anima 190 crank
daytona anima 190f
daytona anima 4v
daytona anima engine
how to build a daytona anima 190
motor daytona 150
