piranha 150 issues
piranha 150 issues
This is a discussion on piranha 150 issues within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; bought a brand new piranha 150 for my stocker. having problems running. put the motor on and got everything hooked up, checked oil level and ...
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By dirtbkr188
Thread: piranha 150 issues
    motoxracr18's Avatar
    Sep 2012
    piranha 150 issues
    put the motor on and got everything hooked up, checked oil level and all
    that good stuff. go to start it up, and man does this thing have some compression
    and back pressure. first kick and the kick starter slung back up.
    cant get it to idle what so ever. only starts with the choke on all the way.
    and dont wana idle nor when i try and rev it up it kills on me. im not a expert on carbs what so ever.
    just seems to me like this motor has alot of back pressure. not sure the next step of what i should do. hellp pleasee.
    it has a mikuni 26 mm carb on it too
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    Engine and Carb quick check list - TBolt USA Tech Database!
    1)Install Intake manifold to head and carb, oil gaskets and tighten bolts lightly at first then torque then down gradually in a cross pattern to provide a good seal and avoid air leaks
    2)Make sure the carb is 100% clean, free of debris and you can see light thru both main and pilot jets
    3)Double check you valve tappet adjustment .003intake and .004exh.
    4)Make sure your exhaust gasket is installed properly.
    5)Make sure all electrical connections are tight and you have a solid ground from the engine to the frame.
    6)Check for good fuel flow and fresh fuel.
    7)See our jetting guide and do a plug read.
    http://www.tboltusa.com/store/tech.php?pid=61
    T Bolt USA - Let's go riding!
    Sep 2012
    this is all brand new items. straight out the box and onto the frame!!
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    Quote Originally Posted by motoxracr18 View Post
    Sure , but please read and check this list it may be helpful
    You Building a Motorcycle now ...
    Sep 2012
    what about timing? think this thing is out of timing are has jumped timing for some reason?? timing should have been set from the factory. what would cuz so much back pressure and recoil of the kick starter????? also why would sometime u cant even push the kick starter down???
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    No , Check the Valve lash and make sure your intake & exhaust are sealed (no leaks)
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    You're not bringing it up to TDC right, and then kicking it over in one smooth even downstroke, that's why you're getting kickback. It also has a lot more compression being a new engine with 3 times the displacement of a stocker. You will also probably have to fine-tune and rejet the carb for your area. Just because it is brand new out-of-the-box doesn't mean that it will work spot-on for you, you have to adjust it to your altitude.
    T Bolt USA likes this.
    - dirtbkr188 -
    Sep 2012
    Intake and exhuast are sealed i promise ya that.
  10. #9
    Sep 2012
    Shouldtiming marks line up in the casings? Witthe t on the rotor lined with the cases, the diamond on the cam gears is not lined up with its notch in the case?!?!?
  11. #10
    is If you're not first, you're
    last
    crf50kid309's Avatar
    Feb 2010
    moorpark CA
    It should when on tdc
  12. #11
    Sep 2012
    Well it aint, think thats causing all my problems,??? I shouldnt be having to mess with time with a brand new out the box, crate
    motor!!!
  13. #12
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    motor!!!
    If the timing is off re-set it ,
    Alot of things in life are not perfect
    Set you Flywheel to "T" mark (top dead center)
    then align you top cam sprocket mark to 9 o clock
  1. piranha yx150 vm24 carb Runability issues/ Jetting Needle advice needed
    By SuperFatboyZ in forum Chinese/Import Minis - General Discussion
    Last Post: 02-03-2012, 12:16 AM
  2. Piranha 140cc clutch issues
    By STIstg3 in forum Chinese/Import Minis - General Discussion
    Last Post: 03-09-2011, 10:25 PM
  3. Piranha trl
    By RRstl1000 in forum Chinese/Import Minis - General Discussion
    Last Post: 11-10-2010, 12:18 PM
  4. piranha 140
    By jerryrice#3 in forum Chinese/Import Minis - General Discussion
    Last Post: 10-20-2010, 06:44 PM
  5. piranha 125 jetting issues
    By eavery in forum Chinese/Import Minis - General Discussion
    Last Post: 08-19-2010, 07:25 AM
2004 piranha 150 pitbike
horsepower of a piranha 150
how to rejet a piranha 140 pit bike
issues with piranha 150 pitbike
piranha 140 timing
piranha 150
piranha 150 clutch problem
piranha 150 horsepower
piranha 150 hp
piranha 150cc horsepower
piranha 150cc hp
pirrahna 150
