Installing Oil Pump on a Lifan 110cc (1P52FHM)
This is a discussion on Installing Oil Pump on a Lifan 110cc (1P52FHM) within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; I am putting a Kitaco oil cooler on my 1970 CT70 with Lifan 110cc motor (1P52FHM) I am looking to install a Daytona or Kitaco ...
Results 1 to 4 of 4
    is full size addict
    HondaStan's Avatar
    Nov 2012
    I am putting a Kitaco oil cooler on my 1970 CT70 with Lifan 110cc motor (1P52FHM) I am looking to install a Daytona or Kitaco high output oil pump for my 110cc lifan motor. Does anyone know if these are first compatible with Daytona oil pumps? I assume they are and judging by pictures they look identical to replacement lifan parts.
    Also, I saw that one has to drill the head to improve oil flow. Does a lifan block require this drilling to be done?
    Any input would be good.
    nielspbr's Avatar
    Feb 2008
    Breukelen, Netherlands
    The lifan 110 uses a 12V oil pump (I do not know the exact capacity, I suspect 180-220 percent)
    is Ride this
    geezer's Avatar
    Dec 2009
    Blackwood N.J.
    should be in china section
    Ride on the edge
    is Ride this
    geezer's Avatar
    Dec 2009
    Blackwood N.J.
    I'm pretty sure you're Lifan has a pretty big pump stock. And you can measure how big the hole is
    Sent from my iPhone using Planet Minis
    Ride on the edge
  1. Installing 7.2mm cam in YX 160, have only worked on Lifan heads before, need help.
    By epod in forum Chinese/Import Minis - General Discussion
    Last Post: 10-18-2009, 09:42 PM
  2. Question on Installing a High Volumn Oil Pump
    By JaxFLCRF70 in forum Honda CRF70
    Last Post: 05-01-2009, 08:23 PM
  3. Installing clutch on 110cc auto engine.
    By btotech in forum Chinese/Import Minis - General Discussion
    Last Post: 12-23-2007, 10:26 AM
  4. Lifan 110cc
    By ppryts68 in forum Chinese/Import Minis - General Discussion
    Last Post: 03-13-2007, 07:27 PM
  5. Question about installing high flow oil pump
    By jbachert in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 05-04-2006, 07:48 AM
110cc lifan oil pump
110cc oil cooler install
1p52fhm
ct70 oil pump installation
how to put a oil cooler on a lifan 110cc
klx 110 oil pump#gsc.tab
lifan 110 oil cooler
lifan 110cc
lifan 110cc oil cooler
lifan engine how to install oil cooler
lifan oil cooler
lifanoilpump
Tags for this Thread
