Chain slack
Chain slack
This is a discussion on Chain slack within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; This chain slack ok? Like between 2 and a half fingers?...
Results 1 to 7 of 7
Thread: Chain slack
    thealaskanbeast's Avatar
    May 2013
    Chain slack
    is living the american dream!
    KlxRacer#2's Avatar
    May 2010
    we scrub harder in Ohio!
    yepp looks good
    2010 BBR 50
    2011 BBR v3
    2004 Honda Cr125
    2015 Piranha 190
    2015 Gorilla 190
    2015 Trail 70
    Thanks to Wholesale-Cycle, TB Parts and BBR Motorsports
    May 2013
    Thank you!
    May 2013
    Chain came off twice..in the rear sprocket. What do I do to fix this? I tried to adjust it tighter
    KlxRacer#2's Avatar
    May 2010
    Look at chain from the rear is it lined up with front sprocket ?
    2010 BBR 50
    2011 BBR v3
    2004 Honda Cr125
    2015 Piranha 190
    2015 Gorilla 190
    2015 Trail 70
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    Drive Chain info - TBolt USA Tech Database!
    Here's the best way to check your chain tension:
    • Use a tie-down to compress the rear suspension so that the front sprocket, swingarm pivot and rear axle are all in line with each other. Use a piece of string running from the centre of the front sprocket to the rear sprocket to identify this. This is the point at which the chain will be stretched to its maximum.
    • Measure the movement in the middle of the chain. There must be at least 20mm of slack. (A)
    Tip: A quick and easy way to check the chain tension is to place your 3 middle fingers on top of each other (like a 3 fingered gun) between the chain and the back of the rubber chain guide on the front of the swingarm. You should only be able to fit those 3 fingers in. This is a good guide but won't be accurate if you have sausage fingers. Do this with your bike on a bike stand with the rear wheel off the ground.
    Tightening your dirt bike chain:
      • Loosen off the axle nut ( until it is only lightly tightened. Wind out the chain adjuster bolts (C) evenly on both sides until you reach the desired tension. You will see the top of the chain rise as you wind out the adjuster bolts.
    • Once you reach the correct tension, make sure both sides are evenly spaced (using the marker grooves on the adjuster blocks). Squeeze the chain against the swingarm with your hand to hold everything in place and tighten up the axle nut.
    • Tighten up the chain adjuster lock nuts. Now you're ready to ride!
    Extra tips:
    • Regularly check that the sprocket bolts are tightened as they can vibrate loose over time.
    • Clean and lube the chain. If you're riding in the sand or really dusty tracks you are better off applying WD40, CRC or a silicon spray. Using a thick chain lube will only attract crap to the chain like teenage boys to a girly-mag.The best way to lube your chain is to place your bike on a bike stand and spray it while spinning the rear wheel.
    • Replace the chain and sprockets at the same time. Chains stretch and sprocket teeth wear. Replacing them at alternate times will shorten their life span.
    T Bolt USA - Let's go riding!
    May 2013
    Klx racer. No it's not. Think I may have put the spacers and everything on wrong. I have 2 larger spacers, one larger than the other by a bit and then a smaller spacer. Also have my rear disk brake holder. It looks out of line.
    And thank you tboltusa..I need to order some new chain adjusters from you guys, how's the easiest way to get the old ones out if the head of the bolt is broken off?
  1. how much chain slack (about) do you have on your 110's
    By ace57 in forum KLX110, DRZ110, TTR90
    Last Post: 06-14-2010, 02:27 AM
  2. Chain Slack
    By motocop729 in forum KLX110, DRZ110, TTR90
    Last Post: 02-26-2010, 08:51 AM
  3. Chain slack
    By bones717 in forum Chinese/Import Minis - General Discussion
    Last Post: 05-20-2008, 05:44 PM
  4. Chain slack?
    By kawasakifan700 in forum KLX110, DRZ110, TTR90
    Last Post: 04-09-2007, 04:49 PM
  5. how much chain slack
    By bennian in forum KLX110, DRZ110, TTR90
    Last Post: 04-09-2006, 06:55 PM
2013 piranha 190 chain tension
planet minis chain lube
what is the chain tension ttr90
