Can someone post pics of normal vs high flow oil pump for honda /and its replica
This is a discussion on Can someone post pics of normal vs high flow oil pump for honda /and its replica within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Hi Can someone post pics of normal vs high flow oil pump for honda /and its replica. The reason is that we have a plethora ...
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By kirrbby
Thread: Can someone post pics of normal vs high flow oil pump for honda /and its replica
    lkhangee's Avatar
    Jun 2011
    pakistan
    Hi
    The reason is that we have a plethora of Chinese Honda horizontal bike replicas ranging from 70cc,85cc,97cc,107cc.
    And most parts for them are interchangeable so I need to know how can I distinguish if one oil pump is better then other.
    A comparison of both will help me probably find better oil pump.
    Sent from my Nexus 5 using Tapatalk
    SS LS1's Avatar
    Feb 2015
    Michigan
    Honestly the one I removed (stock) and the high flow oil pump looked exactly the same. Only difference was when I drilled out the oil supply hole diameter like the instructions said to do so on the engine cylinder.
    1985 ATC 350X all original/OEM Honda parts
    1972 US90 Dickson Designs 2" stretched tube chassis, 200x Forks, Piranha 150cc, VM26
    1985 ATC70 Piranha 114cc BBK, Ported Race Head, TB300 Cam, Spangler's Exhaust
    1985 ATC70 Piranha 150cc, VM26, Z40 cam, Ported head, Two Brothers Exhaust, 2" stretch
    1970 Honda CT70125cc Mikuni 24, XR80 Forks, Aluminum Swingarm, Carbon Exhaust
    1972 Honda CT70110cc e-start, Mikuni 20 carb, Carbon Exhaust, Aluminum Wheels
    1993 Honda Z50R
    2001 Honda XR70R
    Hidden Content
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
    Where you'll see the difference is in the thickness of the pumps. The HV is much thicker than the stocker.
    Sent from my XT1650 using Tapatalk
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
    These pumps are made differently on the backside too. You have to make SURE you use the correct gasket for the pump. The wrong gasket would block the in and out ports on the pump...no flow. The newer style gasket should work for either pump. But the old 6v style gasket will block up some of the newer pumps.
    When you're mix matching, and parts swapping, be sure you have a understanding of how things work, and make sure they WILL work on your motor.
    lkhangee likes this.
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
    lkhangee's Avatar
    Jun 2011
    pakistan
    Quote Originally Posted by kirrbby View Post
    Thanks a lot.
    Is there any pics of the rotors inside the pumps?
  1. high flow oil pump
    By randazzo87 in forum CRF50
    Last Post: 09-09-2009, 11:42 PM
  2. High flow oil pump
    By CRFmx8 in forum CRF50
    Last Post: 02-08-2008, 02:45 AM
  3. Replies: 8
    Last Post: 08-15-2007, 07:54 AM
  4. high flow oil pump
    By kalabula in forum CRF50/CRF70 Parts For Sale
    Last Post: 03-30-2006, 08:49 PM
  5. high flow oil pump question
    By bikeboy4lf in forum CRF50
    Last Post: 10-01-2005, 10:29 PM
