Possible to replace normal rocker arm in E22 head with roller bearing type rocker arm
This is a discussion on Possible to replace normal rocker arm in E22 head with roller bearing type rocker arm within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Hi Is it Possible to replace normal rocker arm in E22 head with roller bearing type rocker arms? And would it make any difference? The ...
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By T Bolt USA
Thread: Possible to replace normal rocker arm in E22 head with roller bearing type rocker arm
    lkhangee's Avatar
    Jun 2011
    pakistan
    Hi
    The head is installed on 88cc Chinese replica off Honda 70.
    Sent from my Nexus 5 using Tapatalk
    lkhangee's Avatar
    Jun 2011
    pakistan
    While I found out that it's not possible to just swap the cam and rocker arms as the design of the head is different. Buy can someone shed some light if heads with this design of rocker arms is any superior?
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    No
    You dont run roller rockers in a plain tappet head
    T Bolt USA - Let's go riding!
    50race's Avatar
    Apr 2004
    North Vernon, IN
    If the roller system is done right the friction losses are less on the roller system and there are some advantages to what cam profiles you can run when using a roller rocker
    is Tinkering
    mrrcx's Avatar
    Jun 2011
    Westlake Village, CA
    Quote Originally Posted by 50race View Post
    Can you provide some examples of this being the case?
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    ROLLER ROCKER HEAD TECHNOLOGY (V2 HEADS)
    TBOLT USA TECH DATABASE!
    TECH-0138
    Roller Rocker Head Technology (V2 Heads)
    The basic concept of the roller rocker design is that it allows for a much more aggressive ramp profiles on cam.
    This allows the Valves to open faster , stay open longer and close faster all giving your engine more fuel.
    Also the roller tip allows for a less friction coeffcient which alots for less parastic losses via friction and heat.
    The Cam rolls with less drag and heat build up.
    All Adding up to a very powerfull system , significant & Substantial Gains over stock.
    lkhangee likes this.
    lkhangee's Avatar
    Jun 2011
    pakistan
    Quote Originally Posted by T Bolt USA View Post
    TECH-0138
    I agree it gives much better performance.
    Here in Pakistan we have Honda CD70 as a work horse. A million units are sold each year. Their 72cc has much better power torque and smooth response compared to 88cc Chinese with plain rocker head.
  1. Rocker arm play?
    By Dragit86 in forum KLX110, DRZ110, TTR90
    Last Post: 07-06-2012, 03:58 PM
  2. Wtb Stock 110 Rocker Arm
    By NickIF in forum Bikes and Parts Wanted - All Makes
    Last Post: 10-04-2011, 11:32 PM
  3. Wtb: Rocker Arm Keeper
    By ThatOneGuy2585 in forum Bikes and Parts Wanted - All Makes
    Last Post: 10-04-2011, 07:27 PM
  4. Rocker Arm Install Questions
    By yernkie in forum CRF50
    Last Post: 05-08-2010, 08:56 AM
  5. rocker arm click - help?
    By fastbmw in forum CRF50
    Last Post: 09-28-2006, 05:28 PM
