Daytona 190 clutch?
Daytona 190 clutch?
This is a discussion on Daytona 190 clutch? within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; I've got a brand new Daytona 190 engine with only a couple hours on it. Here recently it started having issues getting in gear. It ...
Results 1 to 8 of 8
    General Lee's Avatar
    Mar 2017
    Daytona 190 clutch?
    I've got a brand new Daytona 190 engine with only a couple hours on it. Here recently it started having issues getting in gear. It also seems to slip out of gear as well. The cable is adjusted correctly so that's not an issue. Is there a way to adjust the Daytona 190 clutch?
    JESSBENS's Avatar
    Jul 2008
    ZANESVILLE OHIO
    Check your clutch the nut might came lose on u.....that's one thing about these a motors after brake in u need tight up everything case bolts all that.
    Mar 2017
    Ok man, thanks for reply. I'll check it today and report back
    Mar 2017
    Which nut are you talking about? I popped the clutch case off and there are 4 bolts holding in the 4 clutch springs. Do I need to remove those 4 bolts?
    Mar 2017
    Ok I removed the bearing and I can clearly see that clutch nut. I was hoping my crf50 clutch tool would fit, but it doesn't look like it does
    JESSBENS's Avatar
    Jul 2008
    ZANESVILLE OHIO
    Yea hit tbolt up for one they got them with two different sizes on it...
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Right here
    - dirtbkr188 -
    Mar 2017
    Nothing loose. I put everything back together. I get the feeling it's more of the clutch being new than anything. Rides ok. Going to 2nd is a little forced but maybe that's just the way it is..
  1. Daytona 190 Clutch parts
    By T-Wrecks Racing in forum Chinese/Import Minis - General Discussion
    Last Post: 08-02-2016, 04:12 PM
  2. 2013 Piranha 190 4v Daytona and 2011 Pitster Pro LXR Daytona 190 4v Zokes
    By slammed2007lbz in forum Complete Bikes For Sale - All makes and models
    Last Post: 07-19-2016, 10:25 PM
  3. Daytona Anima 150/190 - Upgraded clutch basket
    By BuckIt in forum Import/Chinese Parts for Sale
    Last Post: 12-01-2015, 04:20 PM
  4. Daytona 190 clutch plates
    By catastrophic mx in forum Bikes and Parts Wanted - All Makes
    Last Post: 10-25-2015, 07:03 PM
  5. daytona 190 clutch issue
    By tysons_2001 in forum Chinese/Import Minis - General Discussion
    Last Post: 10-13-2013, 02:13 AM
