Strange noise from engine could it be crank bearings? Video included
This is a discussion on Strange noise from engine could it be crank bearings? Video included within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Hi I have this Chinese 85cc bike. It's making this type of sounds https://youtu.be/TEHI62DzS_E I replaced is timing chain no luck. Replaced piston and new ...
Results 1 to 5 of 5
    lkhangee's Avatar
    Jun 2011
    pakistan
    Hi
    I replaced is timing chain no luck. Replaced piston and new cylinder and still same noise. There was no vertical play in the connecting rod when I removed the cylinder very slight horizontal play.
    I also replaced entire clutch basket and found all the primary drive and driven sprockets in perfect condition. However I noticed slight horizontal play when I pushed the shaft , on which clutch basket is installed, in and out. Here is a video illustrating the free play.
    https://youtu.be/hBkU-Zo0Sm0
    Some descriptions is given in the video description.
    I m suspicion either the crank bearing or might be some thing in transmission.
    Sent from my Nexus 5 using Tapatalk
    is unknown
    soundwav's Avatar
    May 2009
    London Ontario
    My personal opinion and i am no professional..split the case!!! something isn't right
    allenp42's Avatar
    Mar 2014
    I agree; it's time to split the case. Since you have changed the cam chain and clutch, you have ruled out the easy fixes. Have you changed oil and screened for metal filings? The way it sounds, I would expect to find some metal in the oil.
    Salsa's Avatar
    Apr 2009
    Arizona, Alaska, Kalifornia
    Get the old stethoscope and find out where the noise is coming from.
    Don
    lkhangee's Avatar
    Jun 2011
    pakistan
    Quote Originally Posted by allenp42 View Post
    OK I will split cases but is the amount of play and the direction in which it is as shown in video normal? is that normal? I will look for other issues once engine is split apart.
  1. Valves too loud? Video included.
    By TheStock50Kid in forum KLX110, DRZ110, TTR90
    Last Post: 01-27-2012, 12:56 PM
  2. strange smoking engine
    By josect50 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 11-07-2009, 12:48 AM
  3. Really strange 110 engine build
    By nlipshutz in forum CRF50
    Last Post: 07-04-2009, 07:32 PM
  4. My Track Video included
    By GOHARDorGOHOME in forum CRF50
    Last Post: 10-13-2006, 06:55 PM
  5. Strange noise when decelerating
    By Stealhpot in forum Chinese/Import Minis - General Discussion
    Last Post: 04-16-2006, 10:19 AM
