Which TM28 Jet Needles on Daytona 190-4V?
This is a discussion on Which TM28 Jet Needles on Daytona 190-4V? within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Are you guys running the stock jet needle (5DP39) on the 190-4V? I bought a used carb that was off an 184 2V and the ...
Results 1 to 6 of 6
    T-Wrecks Racing's Avatar
    Jun 2015
    Roberts, WI
    Are you guys running the stock jet needle (5DP39) on the 190-4V? I bought a used carb that was off an 184 2V and the jetting was pretty good so I ran it last year, but now I'm out for the max. It has a 190 main, #20 pilot and a 5L1 needle in the top groove (meaning one should drop to the next leaner needle). The stock needle is leaner but could it be too lean? It's also a different taper. I'd play around with it more but the needle is a pain to remove on these carbs. So you all running the stock needles and in what clip position?
    SR160-TX (sold)
    P190R
    TTR125LEL
    CB400F (75)
    JESSBENS's Avatar
    Jul 2008
    ZANESVILLE OHIO
    Wholesale cycle....38 pilot and needle 46-jfq
    Jun 2015
    Roberts, WI
    That's for a keihin carb, my TM28 is a Mikuni.
    SR160-TX (sold)
    P190R
    TTR125LEL
    CB400F (75)
    ahwest's Avatar
    Nov 2015
    based on my research and experience, the stock 5DP39 needle is a 2 stroke needle, 5J6 or 5L1 should work on 4 stroke, at least that's what I'm running with... this applies same to my VM26 carb where I had the stock 5E75 needle and it never ran right until I swapped with a more aggressive needle.
    General Lee's Avatar
    Mar 2017
    I run the stock needle and it runs great. I didn't move the clip up a slot to lean it out a tad
    Jun 2015
    Roberts, WI
    Quote Originally Posted by ahwest View Post
    That explains a lot, as I was also having trouble with a VM26 on my TTR 150. I think I should try a 5J6 with is a tad leaner than the 5L1 in the TM28. Thanks.
    SR160-TX (sold)
    P190R
    TTR125LEL
    CB400F (75)
  1. Daytona FLX -190 and Daytona 125
    By jason04r1 in forum Import/Chinese Parts for Sale
    Last Post: 01-24-2017, 12:32 AM
  2. Daytona 190 vs Zongshen 190 vs yx/gpx 160 with 184 bbk
    By Mayonaise_invasion in forum Chinese/Import Minis - General Discussion
    Last Post: 12-15-2016, 09:25 PM
  3. 2013 Piranha 190 4v Daytona and 2011 Pitster Pro LXR Daytona 190 4v Zokes
    By slammed2007lbz in forum Complete Bikes For Sale - All makes and models
    Last Post: 07-19-2016, 10:25 PM
  4. Daytona Anima 190 to Daytona Trex stator???
    By slammed2007lbz in forum Chinese/Import Minis - General Discussion
    Last Post: 05-25-2014, 08:51 PM
