thread pitch for chinese tank fuel petcock?
This is a discussion on thread pitch for chinese tank fuel petcock? within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; the barb on my petcock is broken by accident, the thread pitch seems to be 5/8-18, but i couldnt find any replacement on ebay they ...
Results 1 to 13 of 13
    ahwest's Avatar
    Nov 2015
    the barb on my petcock is broken by accident, the thread pitch seems to be 5/8-18, but i couldnt find any replacement on ebay they only have metrics, does anyone know where can i find one?
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    What bike is the tank from? Newer CRF/KLX-style or older Z50 style?
    - dirtbkr188 -
    ahwest's Avatar
    Nov 2015
    forgot to mention, it is a chinese gorilla tank.
    dirtbkr188's Avatar
    May 2004
    New Jersey
    I have a TrailBikes aftermarket tank like this one, I can get an OD measurement of the threaded pipe on the tank for you tomorrow sometime, if it'll be any help.
    - dirtbkr188 -
    ahwest's Avatar
    Nov 2015
    that will be very helpful, thank you so much!
    ahwest's Avatar
    Nov 2015
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Without any information in that eBay ad with regards to the ID of the locknut, I'd be leery of buying it. Do you have the means to measure the threaded pipe on your tank, like digital vernier calipers and possibly a metric thread gauge set? If you knew the size metrically, you could ask the eBay Seller to measure it and let you know.
    - dirtbkr188 -
    ahwest's Avatar
    Nov 2015
    i dont have a metric size gauge set at home however i took the broken petcock to orchard supply to try to find out the thread pitch of the nut on the petcock and it seems to fit perfectly on 5/8-18... tried m14 and m16 and they didnt fit... there wasn't a m15 bolt to try so im not sure... i have a caliper that i measure the ID of the nut on the petcock to be ~14.6mm
  10. #9
    dirtbkr188's Avatar
    May 2004
    New Jersey
    I'll get the measurements of the tank I have here and post them up here for you tomorrow
    - dirtbkr188 -
  11. #10
    ahwest's Avatar
    Nov 2015
    the pipe on my tank is measured 16mm, but i'm not sure the thread pitch...
    however i found this 16mmx1.5 fuel tap on ebay
    http://www.ebay.com/itm/Fuel-Switch-...pVeu9n&vxp=mtr
    and according to this size chart
    http://www.custompartnet.com/tap-size-chart
    5/8-18 is very close to m16x1.5, that might explain why it fitted well when i brought the petcock to the gauge set at orchard supply?
  12. #11
    dirtbkr188's Avatar
    May 2004
    New Jersey
    For only 9 dollars, you might as well give it a shot
    - dirtbkr188 -
  13. #12
    ahwest's Avatar
    Nov 2015
    Thanks dirtbkr188! Yea I will give it a shot.
  14. #13
    dirtbkr188's Avatar
    May 2004
    New Jersey
    I measured the tank here and the petcock outlet pipe is 15.86mm OD, and has a 1.5 thread pitch.
    - dirtbkr188 -
  1. CT70 - How long should the fuel line be from tank to petcock?
    By FrankyArseneau in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 08-03-2016, 10:53 AM
  2. KLX 110 fuel petcock or gas tank
    By blackjer in forum Bikes and Parts Wanted - All Makes
    Last Post: 09-02-2013, 04:41 PM
  3. Fuel tank petcock replace advice? 69 z50
    By Dan Z50 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 06-13-2013, 09:05 AM
  4. Anyone Know The Thread Pitch In A Hardtail's Fuel Petcock?
    By mexicanyella in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 03-29-2011, 01:47 PM
  5. fuel tank leak at petcock
    By RAT_FINK in forum Chinese/Import Minis - General Discussion
    Last Post: 05-25-2008, 08:22 PM
