06 Pitster Pro 125 carb problems?
This is a discussion on 06 Pitster Pro 125 carb problems? within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; I need help figuring out what my carb size is. I just recently got it about a month and a half ago. It's a 2006 ...
Results 1 to 1 of 1
    BuiltDiesel's Avatar
    May 2017
    I need help figuring out what my carb size is. I just recently got it about a month and a half ago. It's a 2006 gpx 125cc motor from a 2006 Pitster Pro swapped into a 2011 Pitster Pro frame. It ran fine for a while until about a week ago. I was riding on some trails. Nothing serious. On the way back it was running fine until all of the sudden it started sputtering and backfiring like crazy. After I got it home I let it sit until today to try and figure out what the problem is. It runs and rides fine but the problem is it will not let me go full throttle without dying and start sputtering. If I give it full throttle, it starts bogging down and backfiring. Even in neutral, if I full throttle, it backfires and boggs. I've had problems with this carb before, the overflow is always dripping. Can you help me figure out the carb size? Thank you..
ID:	210322   Click image for larger version.
ID:	210330   Click image for larger version.
ID:	210338   Click image for larger version.
ID:	210346   Click image for larger version.
ID:	210362   Click image for larger version.
  1. Pitster Pro Sherpa 125/Skyteam T-rex 125 bogging down
    By blurpleunc in forum Maintenance
    Last Post: 10-18-2012, 08:19 PM
  2. Pitster Pro 125 RS engine(zonga 125 HO)
    By Juvy in forum Chinese/Import Minis - General Discussion
    Last Post: 01-24-2012, 03:33 AM
  3. Pitster Pro X4 problems.... need help!
    By 6IX in forum Chinese/Import Minis - General Discussion
    Last Post: 10-10-2010, 10:07 PM
  4. Pitster Pro Problems
    By snosleder080 in forum Buyer and Seller Feedback Forums
    Last Post: 08-28-2009, 07:35 PM
  5. 08 Pitster 90 Carb Problems
    By Pitster 90 in forum Chinese/Import Minis - General Discussion
    Last Post: 10-13-2008, 07:13 PM
