Chinese wiring 125cc engine
This is a discussion on Chinese wiring 125cc engine within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Aloha everyone. First time posting and newbie to the Forum. I've searched and found some helpful information but I'm still confused. I have a total ...
Results 1 to 7 of 7
    shanohano's Avatar
    May 2017
    honolulu
    Aloha everyone. First time posting and newbie to the Forum. I've searched and found some helpful information but I'm still confused. I have a total of 10 wires coming from the engine. Five are bundle in a connector and the other five are loose. I've attached photos and really need help with this.
ID:	210442Click image for larger version.
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    one set is likley a gear indicator you wont need
    https://tboltusa.com/store/tech.php?...kely+wont+need
    T Bolt USA - Let's go riding!
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
    What is your project?? What bike are you putting that motor into?
    You could post pics of the existing wire harness from the bike too, and show the colors. We might be able to help you sort it out.
    If your bike is a 6 volt model, and you're changing it over to 12v, it's going to take some work. If your bike is 12v, it should be pretty simple.
    shanohano's Avatar
    May 2017
    honolulu
    Quote Originally Posted by kirrbby View Post
    This project is from scratch. The engine is going into a cart. This engine is all I have so any help would be great on what other items I'll need. the engine is a electric start. Mahalo!
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    If you're planning on using the electric start, you're going to need a battery, a starter relay (solenoid), a voltage regulator/rectifier, a starter button, kill switch, ignition coil, and have to make your own wiring harness to tie everything together.
    If you're planning on using the kickstarter (if there is one), you'll really only need maybe 3 or 4 of those wires, along with a kill switch, ignition coil, and have to make a much more simplified wiring harness to get the engine to run.
    - dirtbkr188 -
    shanohano's Avatar
    May 2017
    honolulu
    Dirtbkr - Mahalo for your reply. Yes I plan on using the starter. Is Tbolt a good source to purchase those items you mentioned? I'd like to use them since they also replied to my post and I guess they are a sponsor. What I gather thus far is the 5 wires on the connector would not be used to run the engine. The 5 loose wires is used for connecting the items you mentioned. When purchasing these items, are there anyone in particular, meaning are all starter relays on Tbolts site the same. Thanks again for all the input. Never thought this far in advance when I ordered the engine...lol
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Yes, Vince at T-Bolt would be the guy to contact for your needs. He has an electric start wiring kit and harness with just about everything you would need to get you started.
    - dirtbkr188 -
  1. Chinese 125CC Engine Dirt Cheap
    By motorheadparts1 in forum Import/Chinese Parts for Sale
    Last Post: 07-21-2012, 10:05 AM
  2. 125cc + chinese engine wanted!
    By StuntinFiddy in forum Bikes and Parts Wanted - All Makes
    Last Post: 09-28-2009, 02:20 PM
  3. Chinese Engine 250cc Air Cooled Wiring Help
    By gonzalocimma in forum Chinese/Import Minis - General Discussion
    Last Post: 02-05-2008, 12:05 PM
  4. 125cc chinese engine covers
    By thorwarrior915 in forum CRF50/CRF70 Parts For Sale
    Last Post: 02-22-2007, 01:10 AM
  5. Chinese 125cc engine case, Where to order?
    By vegatron75 in forum Chinese/Import Minis - General Discussion
    Last Post: 10-21-2006, 11:55 PM
