Daytona 190 running 275f !!
This is a discussion on Daytona 190 running 275f !! within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; I just installed the digital trail spark plug sensor temp meter and it says I'm running as hot as 275f during short 10 - 15min ...
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By mrrcx
Thread: Daytona 190 running 275f !!
    General Lee's Avatar
    Mar 2017
    I just installed the digital trail spark plug sensor temp meter and it says I'm running as hot as 275f during short 10 - 15min rides around the yard. I running the recommended 12 row oil cooler that tbolt sells for the Daytona so I figured I'd be ok on temps.
    What gives? Is 275f even possible without destroying the engine?
    I wanted to ride in Dude Date this year but now I'm nervous about melting the block... Ugh
    is Tinkering
    mrrcx's Avatar
    Jun 2011
    Westlake Village, CA
    spark plug/combustion chamber is where the heat of your engine is generated right? That is where combustion happens. To say that the entire engine is that temp is quite a stretch. Usually when people talk about engine temps they are measuring the oil temperature as that is the fluid that helps cool and lubricate your engine. Different placed n he engine will be different temps.
    T Bolt USA likes this.
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    ^^^^^ agreed on most check the oil temp , the spark plug temp will be higher than the oil temp
    Heres some feedback
    https://tboltusa.com/store/super-oil...reviews_id=168
    T Bolt USA - Let's go riding!
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Pick up one of these to keep tabs on your engine temps in different areas.
    - dirtbkr188 -
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    my taky 124+r would generate spark plug temps in excess of 425 degrees...that temp measurement is pretty useless at the plug.
  1. Daytona FLX -190 and Daytona 125
    By jason04r1 in forum Import/Chinese Parts for Sale
    Last Post: 01-24-2017, 12:32 AM
  2. Daytona 190 vs Zongshen 190 vs yx/gpx 160 with 184 bbk
    By Mayonaise_invasion in forum Chinese/Import Minis - General Discussion
    Last Post: 12-15-2016, 09:25 PM
  3. 2013 Piranha 190 4v Daytona and 2011 Pitster Pro LXR Daytona 190 4v Zokes
    By slammed2007lbz in forum Complete Bikes For Sale - All makes and models
    Last Post: 07-19-2016, 10:25 PM
  4. Daytona Anima 190 to Daytona Trex stator???
    By slammed2007lbz in forum Chinese/Import Minis - General Discussion
    Last Post: 05-25-2014, 08:51 PM
