Mikunis....whats real and whats fake?
This is a discussion on Mikunis....whats real and whats fake? within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; I am finally going to bite the bullet and get a Mikuni vm-26 for a 140cc. Even the ones that claim they are real have ...
Results 1 to 10 of 10
    dsrt4's Avatar
    Oct 2008
    St Louis Mo
    I am finally going to bite the bullet and get a Mikuni vm-26 for a 140cc. Even the ones that claim they are real have wide spreads in price.
    I see 2 different kinds of chokes on the ones that claim they are real. One push pull Style and one lever style. Both call them vm26's.
    I appreciate being set straight as to which one I need. I assume I will have to buy a flange mount or lop off the flange and go with a short tube to run these.
    Here's the two I am looking at. Motor is stock but has exhaust.
    http://www.ebay.com/itm/New-Real-MIK...NS-Pep&vxp=mtr
    Lever style.
    http://www.ebay.com/itm/Mikuni-26mm-...1YqIpU&vxp=mtr
    Salsa's Avatar
    Apr 2009
    Arizona, Alaska, Kalifornia
    Go for the one with the big titts !!!!!
    Don
    dsrt4's Avatar
    Oct 2008
    St Louis Mo
    Those definitely aren't fake!
    On a more serious note....
    Is the fake one the lever style or is that just a different model of mikuni vm26?
    loopiemclooperson's Avatar
    Oct 2011
    Maple Valley WA
    The lever style is not a genuine Mikuni VM26-606.
    The first link looks like the real deal, even has a sudco sticker on the float bowl.
    Not sure what intake you have currently but you will need one with a spigot mount. Here are the specs for the VM series...
    MIKUNI VM CARBURETOR CARB vm34
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    Both look genuine at a glance , however may be a waste of money because of the carb slide being not appropriate for these lil 4 strokes
    slides cost like $60
    the units we offer have the correct slide ...
    https://tboltusa.com/store/tbparts-m...606-p-742.html
    T Bolt USA - Let's go riding!
    jamesfl's Avatar
    Dec 2016
    I don't know Mikuni carbs at all but ran into a situation with some Keihin carbs recently. Both of the carbs had "Keihin" on them but turns out that they were Officially Licensed Chinese made carbs designed for the Asian markets and not Keihin Japan made carbs. The Chinese made "Keihin" Carbs would not accept Keihin slow jets available in the US market. You may want to ask the seller if they are Mikuni Japan made carbs or Chinese made Mikuni carbs? Mine came in boxes that said made in China.
    dsrt4's Avatar
    Oct 2008
    St Louis Mo
    Quote Originally Posted by T Bolt USA View Post
    What makes the slide not being appropriate for the smaller engines?
    I don't know anything about them. Is it the way the throttle cable Connect's to it?
    dsrt4's Avatar
    Oct 2008
    St Louis Mo
    Quote Originally Posted by loopiemclooperson View Post
    I have the carb that came with the engine from tbolt. It has a bolt on flange to the intake with Like a 48mm bolt pattern.
  10. #9
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    Quote Originally Posted by dsrt4 View Post
    Our carbs TBW0399 carb comes with a small amount of cutaway so its richer right of the bottom
    2 stroke carbs have bigger cutaway so they are leaner off the bottom
    Its similar to why bigger carbs like on a YZ250F had an accelerator pump (pumper carbs)
    TECH
  11. #10
    dsrt4's Avatar
    Oct 2008
    St Louis Mo
    Thanks T bolt. I'll need to save a bit and get the one from you. I'm tired of dealing with this.
  1. Getting hard to tell whats real and whats fake
    By mx_master in forum Off Topic
    Last Post: 11-28-2014, 11:09 PM
  2. Z50 fake or real? Should I do it?
    By Tedted98 in forum Z50, CT70, ZB50 and other Honda Parts
    Last Post: 03-01-2014, 11:56 PM
  3. Real Marzocchi forks vs. fake ones
    By crazyj23 in forum KLX110, DRZ110, TTR90
    Last Post: 01-07-2014, 09:40 AM
  4. Real Or Fake
    By iVorTec in forum CRF50
    Last Post: 07-26-2011, 08:41 PM
  5. looking to build a mini, whats good and whats not?
    By cooter21 in forum Stunt Minis
    Last Post: 01-21-2010, 09:35 PM
