Sudden change in carb performance - Page 2
This is a discussion on Sudden change in carb performance within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Have a pic of the carb? Which way are you adjusting the fuel screw to richen it?...
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    - dirtbkr188 -
  2. #17
    jamesfl's Avatar
    Dec 2016
    Quote Originally Posted by damnbiker View Post
    The bike has been run regularly, so unless something solid went through the fuel filter, I highly doubt clogged passages.
    Unless you have always run ethanol free rec fuel, you may want to do a google search for "ethanol and rubber fuel line".
    Keep in mind you have a small bit of rubber fuel line after the fuel filter. Then you could also have varnish build up in the pilot.
    Until I can do this:
    And see smooth round opening like this:
    I consider the pilot clogged.
  3. #18
    damnbiker's Avatar
    Jun 2014
    Fuel screw going counterclockwise to richen. Its located at the bottom of the engine side of the carb.
    I can see a super clear round hole through my pilots, and run a thin wire through no problem.
    The tiny passages INSIDE the carb, I have no way of telling besides witnessing fuel vapor fly out the other end when compressed air is applied. I also soak the whole thing in an ultrasonic cleaner as suggested.
    Maybe its just time for a new carb? Its an SSR E2 125cc, any good cheap carb recommendations? I don't need crazy power or genuine Japanese parts, just something that will run smooth at low to mid throttle for getting around the farm. I have a Piranha 190 for when I need to go faster lol
    Salsa's Avatar
    Apr 2009
    Arizona, Alaska, Kalifornia
    At one time there was a sign on the wall of the Carter Carburetor school that read,
    "90% of all carburetor troubles are electrical" ( this was before electrical feedback carburetors)
    Don
  6. #20
    jamesfl's Avatar
    Dec 2016
    Curious if a new carb solves the issue?
  1. Help! All of a sudden no spark!
    By Miasma in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 08-18-2014, 08:40 PM
  2. Any one have any experience with this carb? 28mm Performance Carb [TBW0490B]
    By mcj66106 in forum Chinese/Import Minis - General Discussion
    Last Post: 01-18-2013, 10:13 AM
  3. 108Cc Stroker, 20Mm Carb, Sudden Bogging??
    By Towlieee in forum CRF50
    Last Post: 05-04-2011, 08:52 PM
  4. YSR50 sudden loss of power :(
    By blurry in forum NSR50, NSF100F, MB5, NS1 and RCV Mini
    Last Post: 07-15-2008, 12:26 PM
  5. big performance with carb change??
    By canufeelme in forum CRF50
    Last Post: 02-17-2006, 02:57 AM
