146cc big bore kit for yx125
This is a discussion on 146cc big bore kit for yx125 within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Wanted to buy the 146cc big bore kit for my yx125. Looking for input from others who have done this. Is it worth it or ...
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By String
Thread: 146cc big bore kit for yx125
    String's Avatar
    May 2017
    Wanted to buy the 146cc big bore kit for my yx125. Looking for input from others who have done this. Is it worth it or should I save the money and buy a bigger motor. Was looking at the kit from tbolt but also heard there's one from sgr?
    Thanks
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    You going to need to run a big valve head in the YX125 since the only pistons availible are for that head (not the stock small valve YX125 heads)
    T Bolt USA - Let's go riding!
    String's Avatar
    May 2017
    Ok is anything else required or does that kit have everything I need?
    T Bolt USA likes this.
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    Quote Originally Posted by String View Post
    Kinda wide open question ...
    The kit includes
    New big valve head
    Cylinder
    piston
    rings
    Pin
    Clips
    Head and base gaskets
    You DONT re-use the original O rings between the head / base / cylinder
    You might need a few gaskets on the head at the cam cover and top plate if they tear
    We have a full gasket set listed
    You should consider a Race cam too
    and possibly a VM26 606 carb ...
    String's Avatar
    May 2017
    Ok cool. I appreciate your help. What would be a compatible race cam?
  1. 146cc HC bore kit
    By モンキ in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 11-14-2015, 05:44 PM
  2. Big Bore BBR 160cc kit or Big Bore Trial Bikes 165cc kit??
    By -Kawi kid56- in forum KLX110, DRZ110, TTR90
    Last Post: 09-30-2009, 03:24 PM
  3. GPX 125 cc engine and 146cc TB big bore
    By lawson87 in forum CRF50/CRF70 Parts For Sale
    Last Post: 07-10-2007, 05:55 PM
  4. What is the best 146cc big bore kit out there for the GPX motor?
    By DEMON_CR in forum Chinese/Import Minis - General Discussion
    Last Post: 04-22-2007, 08:44 PM
  5. NEW 146cc CUSTOM GPX ,PITSTER and THUMPSTAR BIG BORE
    By T Bolt USA in forum Vendor Area
    Last Post: 11-20-2006, 08:53 AM
