CRF Import Wiring Guide - Page 2
This is a discussion on CRF Import Wiring Guide within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; the one in the picture is a regulator/rectifier I assume you can get just a regulator and just a rectifier if you wanted...
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 34
  1. #16
    panaman's Avatar
    Nov 2006
    Columbus, Ohio
  2. #17
    is Teaching math
    Z50King's Avatar
    Sep 2004
    Glendale, CA
    so my new loncin has four extra wires under the tank. if i take a pic, can you guys tell me what to do and what to buy so i can run lights on the thing??
    id take it now, but my camera is at my cousins house, left it there christmas day
    i just got done putting the tank and plastics back on, so i know how to take them off pretty easily to get to the wires
  3. #18
    RB Racing's Avatar
    Oct 2005
    Winnipeg,Canada
    Here's the ones I got with my Lifan.
    64 C110
    74 XR75
    83 XR80
    87 XR100
    76 Z50/110 Resto Mod.
    07 1098 Ducati
    07 S4RS Ducati
    09 CRF450X
    RuSoLiNiO's Avatar
    May 2007
    First post. Hi all. Anyway, heres a pic i found of the kitaco inner rotor copy wiring diagram. Bought one off ebay, and it didnt come with wiring instructions. Worked for me just great!
    If your bike has a killswitch thats earths to the bars, the earth to frame wire should not be connected to the frame or misfiring, popping and banging will occur! (as i found out!). Simply connect the earth to the neg (black on my chinese copy) wire of the killswitch.
  6. #20
    is Teaching math
    Z50King's Avatar
    Sep 2004
    Glendale, CA
    Re: CRF Import Wiring Guide
    i got me an irk in installing on monday
    might need this page!
  7. #21
    sniper8988's Avatar
    Mar 2008
    Hey guys I am new to this forum i'm hoping i can get some help with my engine. I just bought a brand new Lifan 110cc engine w/ electric start but i dont want to wire it for electric start. I cant find a wiring diagram that matches my engines color wires and its getting really frustrating so maybe someone has some info for me. My coil wires are Green and Black/Yellow. My engine wires are Yellow, Black/Red, Pink, Blue/White, Green. And on the stator wires are Blue/Red, Purple, Green/Red, Green/Black, and Pink. Its a 5 wire CDI system. If anyone knows how to wire this thing up PLEASEE let me know!!!
  8. #22
    mr2jspec94's Avatar
    Oct 2007
    Fort Worth, Tx
    Here is the diagram for the standard china inner rotor kit. works for most chinese inner rotor kits.
  9. #23
    rob c's Avatar
    Jun 2008
    hi i have a imported 4stroke chopper (crf import engine)
    it has nothing like a coil, cdi, rectifier etc on it
    just has a 6 wire plug plus a seperate black and red white
    the 6 wires on the plug are yellow, white, red, blue and yellow, green and green and red
    what do i need to get this engine running?
    can i test the magneto some how to make sure that it is all working?
    regards,
    rob c.
  10. #24
    97super10's Avatar
    Jul 2008
    I need a wiring diagram for a zongshen 125 motor to hook up a headlight. Secondly will the Baja Designs dual sport kit for the crf50 work off of my wiring?
  11. #25
    chris116's Avatar
    Sep 2008
    san diego
    hey dude a buddy of mine just picked up a boreem 80cc pit bike and this thing had an electric start and we took it off and theres like a big mess of wires! anys ways i was wondering, where do i i connect the wires that come out of the cdi box??and where do i connect the wires coming out of the stater? this bike hasnt been ran in a year according to the guy that he pick it from. so if you can please help me and my buddy out i would really appreciate it.
    thanks
  12. #26
    fastlane28a's Avatar
    Aug 2008
    Here is the wiring we used to install a GPX 124 in my CT-70 pit bike. It runs a headlight & tailight.
    I recently swithed to a KRP 150 with an outer rotor & flywheel. I need a diagram to show how to wire that motor. Anyone?
    Thanks
Name:	Scan - Electrical diagram GPX 124.jpg
ID:	32669   Click image for larger version.
Name:	Dyno Run 2.JPG
  13. #27
    Wraith's Avatar
    Aug 2008
    rio rancho , NM
    i have a jailing motor and have a IRK from G2moto.com. can some one help me with the diagram?? i hooked it up ones and no spark. i tried everything. someone told me that the motors are difficult to start with the IRK installed and if the jetting isnt spot on, it will be difficult to start.
  14. #28
    aaron33_dg@f's Avatar
    May 2008
    PERRIS, CA SO CAL
    great stuff guys we know who 1are the best you guys got ta brains
  15. #29
    Studster's Avatar
    Sep 2008
    western NY
    eBay Motors: INNER ROTOR KIT CRF50 CRF 50 XR XR50 70 Z IGNITION IR01 (item 330286210616 end time Mar-12-09 1920 PDT)
    how can i wire this to my zongshen.. i have been having a hard time figuring it out the directions make no sense!
  16. #30
    kawasakicoby125's Avatar
    Jul 2008
    Lynnwood, WA
    ok, i cant find out what my wires are for my ogm125, is a yx, with 6 wires out of the strator. ive tried so many supposed wiring combonations, none worked. help me please
5 wire blue/white black/red green 2 yellow stator
5 wire stator diagram
72cm3 2 1 wiring
color coding for cdi
honda cd 70 4 pin rectifier 110cc wire yellows and white and green and ground state wire open
how to wire motorcycle regulator with 5 wires
loncin 125cc wire diagram
pit bike wiring diagram
ssr 125 12v coil
where does green wire go on lifan 125cc stator plate
wiring diagram 4stroke pit bike 110 cc db10
zongshen rectifier 6 pin 3yellow 1green 1red 1black wiring diagram
