CRF Import Wiring Guide
This is a discussion on CRF Import Wiring Guide within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; OK guys, here we go. This is it. No diagrams, no drawings. Just pics. Here, we have the 5 wires coming from the stator Note ...
Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    mattv's Avatar
    May 2005
    Omaha, Nebraska
    Note these two wires: (yellow and white)
    We will NOT need these wires. Yellow is for lights and white is for charging a battery.
    Moving on to the KILL SWITCH:
    Your kill switch may ground itself on the bars. The green wire is a ground. Black wire goes to the CDI.
    Moving on to the COIL:
    We have a RED/BLACK wire, and a green wire. Green wire is a ground. Here's one more picture showing the coil. It's a stock china coil from an SSR bike and the red/black and green wires are attached.
    mattv's Avatar
    May 2005
    Omaha, Nebraska
    alright guys - let's get some more wiring diagrams in here....
    I'll find all I can and get them up. Anything you guys find -- leave links here. I'll fetch the images and get them on my stable server so they don't go anywhere....
    JohnnyB's Avatar
    Nov 2003
    CT
    I 'm look'n for the GPX schematic if anybody's got it ???
    Thanx !!!
    Just say'n .... Hidden Content
    CRF#319's Avatar
    Dec 2005
    Kelowna, BC Canada
    I found this one over at dratv.com.
    My Zongshen 120 has six wires out of the stator color-coded like in the diagram.
    Cheers, #319
    '04 CRF150 w/CR85 suspensionHidden Content
    '05 RCM 125SXHidden Content
    Project "stocker" build Hidden Content
    is brap braappp
    xr70racer's Avatar
    Feb 2006
    Glen Mills, PA
    Im having a porblem with my wireing for my Lifan 120. I have an xr70 kill switch and have no where to put it. I have to connect it to a green and a black and white wire. I just don't know how to connect them because there is a plastic connector. ALso how do i connect the wires. Just slip it into the other one and maybe tape it??
    Andoru's Avatar
    Sep 2006
    hey there, i have a green wire coming out of the strator, and also a yellow and black wire coming out of the coil. where do they go? could anyone help me out? thanks!
    moto-mac's Avatar
    Nov 2006
    La Grande,OR
    I'm trying to wire in a regulator and lighting for my bike any diagrams or help on that!!!
    Kurlon's Avatar
    Feb 2005
    Southern Maine
    Regulators usually have one wire (yellow) to accept input from the lighting coil. They have one wire, green or black to go to ground, and a red wire that will be your 12v positive regulated output.
  10. #9
    moto-mac's Avatar
    Nov 2006
    La Grande,OR
    is there a way to check the wires coming out of the stator to see for sure which one it is, should I be able to check it with a volt meter, and will it be ac or dc
  11. #10
    TRT
    TRT is offline
    is chillin in the D
    TRT's Avatar
    Nov 2005
    Earth
    The whole system is a 12vDC.
    This page should help you figure out any system that you may have:
    http://www.hooperimports.com/showpages.asp?pid=1013
    Troy
    One fine day!
  12. #11
    moto-mac's Avatar
    Nov 2006
    La Grande,OR
    I understand that its 12v but I think its ac before the rectifier because straight out of the stator I get ac voltage but no dc voltage. does anybody know the test procedure for the wires at the stator??
  13. #12
    Trail Punisher's Avatar
    Nov 2006
    Harrisburg Ohio
    Here is a pic of diagram.
    In China green is ground instead of black.
    Flameout is Kill switch.
    You can ignore the electric start stuff.
    12 volt Chinese engine project involves 2 wires from the engine- usually
    Black/red from engine can also be yellow/red in some cases is power to cdi box-
    usually goes to red/yellow in the harness-leads to CDI box
    Blue/white from engine can also be red/white in some cases and is the cdi trigger/pulse-
    One wire from the CDI box to the Coil (+), Coil (-) goes to ground.
    Black/yellow wire from cdi box harness goes to the coil + which can be black/yellow stripe or black/white stripe .
    This will get a 12 volt engine running.
Name:	ZongshenLifan wiring diagram 1.jpg
  14. #13
    panaman's Avatar
    Nov 2006
    Columbus, Ohio
    ok... i am so puzzled...
    Basically I have a SSR110A-1 it has a yellow wire and a white wire.
    I get AC voltage out of the yellow wire.
    I bought a 3 wire regulator/rectifier from a local shop (its from an artic cat but should still work fine i would think)
    The regulator/rectifier has Yellow, Red, and Black wire.
    I plugged the yellow wire from the reg/rect to the yellow wire on the bike. I hooked the black wire to ground and I only get 3 volts DC out of the red wire instead of 12v
    Do you guys think thta maybe my regulator/rectifier is effed.. or just wrong since its for an artic cat snowmobile?
    oh yeah.. don't know if this will help but the regulator has the following part numbers..
    ARCTIC 0630-105 and 01-154-18
  15. #14
    panaman's Avatar
    Nov 2006
    Columbus, Ohio
    this is what my regulator/rectifier looks like
  16. #15
    yzf_nick56's Avatar
    Mar 2004
    Lewisburg PA
    Quote Originally Posted by moto-mac
    I was finding the same thing out last night. do regulators have rectifiers built into them?
5 wire blue/white black/red green 2 yellow stator
5 wire stator diagram
chinese mini chopper wiring diagram
color coding for cdi
loncin 125 wiring diagram
loncin 125cc wire diagram
pit bike wiring diagram
pit boss 110cc chopper wiring diagram
where does green wire go on lifan 125cc stator plate
wiring diagram 4stroke pit bike 110 cc db10
wiring diagram for a pit pro stator plate to lume
zongshen rectifier 6 pin 3yellow 1green 1red 1black wiring diagram
