Import Motor FAQ - Long Stroke Mills - Page 2
This is a discussion on Import Motor FAQ - Long Stroke Mills within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; I have 2 china 110's that from exterior measurments are the same, both are stamped as 107's one is my oldest sons, one is my ...
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 71
Like Tree1Likes
Thread: Import Motor FAQ - Long Stroke Mills
  1. #16
    ghostryder's Avatar
    Jan 2006
    northern california
    I have 2 china 110's that from exterior measurments are the same, both are stamped as 107's one is my oldest sons, one is my daughters. I just recently bought another. Its an ebay special I got very, very cheap. Its stamped 107 but the cylinder appears to be close to 1 inch longer and 1 inch narrower than the other two. The kids bikes run really well and are semi auto's, this new one is gutless as can be and is a manual clutch. I bought it hoping to sell it for a small profit but if that doesnt happen will integrate it into the family and definately want to pep it up. I didnt realize the china 110's could be so different. Any clue which one this new one is. The old ones appear to be fairly square(bore x stroke) from the outside, this new one is more rectangular.
  2. #17
    TRT
    TRT is offline
    is chillin in the D
    TRT's Avatar
    Nov 2005
    Earth
    Here's one for ya...
    I tore apart a 124cc only to find that it's stroke was only 49.5 and bore 52.4...
    Thats not the unusual part though. The cyllinder was actuallly 78mm tall...Figure that one out. Most 110cc based engines 107,108.. have the 69mm tall cylinder with the 49.5 stroke and 52.4 mm bore.....????????Hmmm
    Troy
    One fine day!
  3. #18
    Pat Farsole's Avatar
    Nov 2006
    Quote Originally Posted by Kurlon
    Interesting, where did you get the gearbox data? That's a much closer ratio setup that I'm using to seeing in an import mill.
    It's on the ebay listing under engine specs . Whether it can be trusted or not I don't know . What I can do is mark the flywheel and countershaft sprocket and count the flywheel turns to each C/S sprocket turn in each gear .
    Nov 2006
    http://cgi.ebay.com.au/ws/eBayISAPI....ype=osi_widget
  6. #20
    is Teaching math
    Z50King's Avatar
    Sep 2004
    Glendale, CA
    i have some info on the Loncin 107(called a 110) 3 valve engine.
    VIN id numbers:
    #.) VIN= engine id
    1.2.) LC= Loncin
    3.) 1= single cylinder
    4.5.) 52= rounded off for bore size of 52
    and then i think the rest of it is all engine# from the run
    mine says on the Ohalee website that its a 52.4x49.5
    it is a 3 valve with two intakes and 1 exhaust.
    also has a left-side cam chain and sprocket.
    Identifying marks are:
    "Loncin" on the left-side cover, as well as "Designed in Japan" curved underneath it.
    "3valve" on both the upper tappet and the cam side cover
    ill post some more specs if i take it apart
  7. #21
    is Teaching math
    Z50King's Avatar
    Sep 2004
    Glendale, CA
    the last three numbers on the top row,
    FAH or FMH
    A = automatic clutch
    M = manual clutch
    i dont think anyone knows what F or H mean
  8. #22
    Nov 2006
    Winston, have you actually measured the bore and stroke on that motor?
    (And for reference, the Lifan 'Monster' tag refers to a specific Lifan 120 motor, all others are not monsters despite similar specs or bottom ends.)
    Kurlon is dead right . The actual 120 monster Lifan has ports that are larger (wider) , smoother and cleaner finished inside and the casting around the guide is larger diameter than the later "R" type big valve heads .
  9. #23
    Nov 2006
    Quote Originally Posted by jkline805
    hey i have the same Lifan big valve with the 124cm3 on the cylinder that turned out to be a 52.4x55mm, but the funny thing is, my engine # is 156FMI. I dont think that you can trust any of the markings on the cylinder and apparently not the model # either. oh well.
    Take a look inside your inlet port and IF the casting boss around the guide is a large diameter and the port is a smooth , clean finish , you have a genuine 120 "monster" motor . We have one of them and it is a 156FMI . I pulled the head off it new to check the bore to see if it was 56 mm but it was only 52.4 . The 124 big valve 1P52FMI motor turned out to be a 120 with ports that aren't as good as the genuine monster 120 !
  10. #24
    little_twin's Avatar
    Jan 2007
    Novato, Ca
    Just a little info I gathered while putting my 54x54 back together.
    Cam=short 68mm
    the wide spaced valve springs from DrAtv were too short, and "softer" than the stock valve springs.
    The 56mm copper head gasket worked well, but required a small amount of modification.
    I dont think the valves on mine are 27, 23 but I didn't measure them.
  11. #25
    Moderator
    ~E's Avatar
    Nov 2003
    San Juan Capo, CA
    Quote Originally Posted by Z50King
    FAH or FMH
    M = manual clutch
    "For Auto Hammering"
    "For Manual Hammering"
    lol. Great thread Kurlon. Need more like this.
  12. #26
    Banned
    firepower354's Avatar
    Oct 2006
    Flint MI
    Has anyone compiled a list of the con rod and crank pin specs on the Chinese motors? I'm looking to do some parts swapping.....
  13. #27
    Kurlon's Avatar
    Feb 2005
    Southern Maine
    I've not seen that info posted anywhere yet.
  14. #28
    Banned
    Oct 2006
    Flint MI
    Anyone got ANY specs? We gotta start somewhere.
    The 50 I just tore down has a 23x39 pin. Rod has 28x14 BE. 94mm long.
  15. #29
    Banned
    dragndave's Avatar
    Aug 2006
    south florida
    the gpx,sdg 107, lifan 120, and every 90-110cc china motor has a 25x39 pin and the rcm 120 has a 26x39 pin.the honda 50-70 is smalled diameter but same length
  16. #30
    brettt's Avatar
    Jun 2007
    Re: Import Motor FAQ - Long Stroke Mills
    got a loncin 125
    says 123 on cylnder
    bore 52.5 stroke 67.5
    pin hole 14 to piston top (flat piston)
    14 pin
    cyl height 69
    intake 23
    exhaust 19
    is this a 120?monster?
    bought a 138 kit from china the bottom of cylnder doesnt fit in the case hole
    and the studs are spaced different
    can i mod the cyland cace to fit or is it wrong
    china guy told me its for ducar 125
    also got inner rotor cdi light oil slinger works sweet rev-o-matic
124cc 1p52fmi
124cc gongyu motor
124cc zongshen best exhaust
gongyu 124 cm3
gongyu 124 cm3 parts
gongyu engine 124 manual
how to fix timing ongongyu 124 cm3
motorcycle parts 125 gongyu engine
what clutch does a gongyu 1p54fmi small valve head use?
zongshen engine zs154fmi-2
zs154fmi compression ratio
zs154fmi zongshen 124cc specs
