Import Motor FAQ - Long Stroke Mills - Page 5
This is a discussion on Import Motor FAQ - Long Stroke Mills within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; I have a 124cc engine, says GPX on the Left Side Cover. Any way to determine who actually manufactured this engine? Numbers are- Model -1P52FM1 ...
Page 5 of 5 FirstFirst ... 345
Results 61 to 71 of 71
Like Tree1Likes
Thread: Import Motor FAQ - Long Stroke Mills
  1. #61
    drb930's Avatar
    Jan 2010
    Los Angeles
    Re: Import Motor FAQ - Long Stroke Mills
    Numbers are- Model -1P52FM1 S/N 05A119288
    Want to put a Cam in it and need to know which one to get?
    Thanks,
    Dave
  2. #62
    RD350's Avatar
    Jan 2009
    Crucible, PA
    I have a SDG pro mini 125. Where can I buy engine parts. Third gear went out.
    It goes threw 1st gear and 2nd fine, but when I shift to third it feels like it goes to neutral. You can shift right out of it to fourth third is not there. Anyone who had similar problem, can you help me out.
  3. #63
    is currently licking windows
    doopsx3's Avatar
    Aug 2008
    Yucca Valley
    Quote Originally Posted by RD350
    pm Firepower354...he should have the stuff you need
    is Ride this
    geezer's Avatar
    Dec 2009
    Blackwood N.J.
    What about 150 engines, Some have honda head, som kaw, Whats the difference? Do parts innerchange. Same stud pattern?
  6. #65
    530mini's Avatar
    Apr 2010
    Redding, CA
    I have been trying to figure that out myself. Apparently there are many mysteries with these motors lol I think they make the gearbox Z/XR/CRF50/70 style, and then put a KLX top end (jug/slug/head) on them, but I do not know for certain. Not sure what the difference is either, or if there is any sort of advantage. I have seen exhaust adapters for the klx head but they don't specify what they are for. I read a post that said klx heads use bigger valves, but what style makes more usable power I have read mixed opinions. Sucks being a noob lol
  7. #66
    doopsx3's Avatar
    Aug 2008
    Yucca Valley
    Quote Originally Posted by 530mini
    isn't that basically a YX...IDK
  8. #67
    Lee337's Avatar
    Dec 2009
    Okay my block tag reads 1p52fmh7c05698. Has 5 point stars engraved on each end. Tag says its a 110. Cylinder says 107cc and the piston says L 110. So is this a lifan? And it looks just like honda head. Anyone help me with what motor this is?
  9. #68
    Lee337's Avatar
    Dec 2009
    Sorry the number is 1p52fmh7c056988 I forgot to put that last 8..
  10. #69
    Lee337's Avatar
    Dec 2009
    And my piston measures 54
  11. #70
    flower's Avatar
    Jun 2008
    MO
    Somebody care to bring this thread up to date ? and continue it for those of us who would like to know what they are finding out about the motors being sent out today?
    Live to ride or ride to live that is the question.
  12. #71
    Rangerscott's Avatar
    May 2013
    Texas
    minishifter likes this.
124cc 1p52fmi
124cc gongyu motor
124cc zongshen best exhaust
gongyu 124 cm3
gongyu 124 cm3 parts
gongyu engine 124 manual
how to fix timing ongongyu 124 cm3
motorcycle parts 125 gongyu engine
what clutch does a gongyu 1p54fmi small valve head use?
zongshen engine zs154fmi-2
zs154fmi compression ratio
zs154fmi zongshen 124cc specs
