My brother in law has a 120 lifan motor it was running fine and then he stoped and tryed to re start it and it was running but would not go into gear???? What is wrong??????
This is a discussion on lifan 120 problem within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; My brother in law has a 120 lifan motor it was running fine and then he stoped and tryed to re start it and it ...
sounds like a big tranny problem. has he rode it hard dry shifted or powershifted alot? ive owned my lifan and had no problems yet.. but if my tranny fails me im forsure getting the GPX bottem end and keeping my lifan head. ur bro could have worn the plates out or bend the shifting forks. take off your clutch cover and inspect is what i would do.
it has bent shift forks from flat changing gears.
There is no rite or wrong just what works!
When you say would not go into gear, exactly what do you mean? Are you not able to move the shifter up and down or does it go in gear but not move when you let the clutch out?
I will check the shift fork. He says that he puts it in gear and he hears a click and nothing. He says the shifter moves the same as always. What does the shift fork look like???
without it running, prop up the back wheel and move it back and forth to try and get it to rachet into gear. if it feels like it clicked into gear and you feel a little more resistance then maybe it is the clutch.
start it up with the wheel prop'ed up without a load while running if it rotates at all its in gear, but the clutch is the problem.
in the pic the fork is number 1
I will check it out.
What is flat changing Gears????Originally Posted by rjpracing
holding it wide open and power shifting!
Thanks, I would guess he did alot of that.
