rebuilding a 110cc top end
This is a discussion on rebuilding a 110cc top end within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Hi to all and hope to get some help.I am working on a 110cc chinese bike and started to smoke so i decided to open ...
Results 1 to 6 of 6
    jrswerkz's Avatar
    Nov 2006
    Hi to all and hope to get some help.I am working on a 110cc chinese bike and started to smoke so i decided to open her up.First of all are these cylinders nikasil or can it be lightly honed and just install new rings(bore is 52.)The only 4-stroke ive worked on are chevy engines so i see no major difference.Sorry but i really dont know the brand but has a sticker -Y N B Motors with 8 balls in the center.I hope i gave enough info and can get some advise.Thanks again
    RcWannabe's Avatar
    May 2006
    Erie, Pa
    They are not nikasil cylinders and your motor if it is an import is probaly 52.4 mm bore so there is quite a few options as for a piston. Or if it is 52mm which I dont think any china motors come with there are lots of 52mm pistons out there too. Well 110 china motors actually are 107cc and they are usually 52.4 mm bore with a 49.5mm stroke. Also if you could post a pic of it we could help id it.
    Founder of the Fl Mullisha....Pa Chapter
    2006klx110rider's Avatar
    Oct 2006
    Apple Valley,California
    i can almost guaruntee (sp) the chinese companies dont use nicaksil considering its cost and how cheap they make the bikes for.
    RcWannabe's Avatar
    May 2006
    Erie, Pa
    I know it is not nicasil
    Banned
    dragndave's Avatar
    Aug 2006
    south florida
    dont bother re-ringing it just drop in a tb114cc kit.
    jrswerkz's Avatar
    Nov 2006
    If its not nikasil(and it is 52.4mm)can i just hone and ring or just ring it without the hone.It is my wifes bike so she doesnt need alot of power ,stock scares her enough.
110 chinese engine rebuild
110cc engine rebuild
110cc head rebuild
110cc rebuild
110cc top end rebuild
how to rebuild 110cc engine
how to rebuild a 110cc engine
how to rebuild top end on 110 4 stoke chinese motor
ow to rebuil the top end on 110 cc chinese
y n b motor
ynb motor parts
ynb motors
