Sikk Mx 125cc Wont start
This is a discussion on Sikk Mx 125cc Wont start within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; I have a Sikk Mx 125cc bought 2006. Bike wont start. There is spark,compression looks Ok. Im confused on timing setting. It has a Gpx/Jialing ...
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Pitpower1's Avatar
    Oct 2007
    I have a Sikk Mx 125cc bought 2006. Bike wont start. There is spark,compression looks Ok. Im confused on timing setting. It has a Gpx/Jialing motor. I was told piston should be at TDC when T mark on flywheel is alligned with the notch on the casing,but this is not. piston is at BDC when T mark is alligned with notch. Anyone can tell me what should it be? Appreciate If someone can tell me exactly how to set the timing. I've ben working on it for a month now and still have no clue as to why it will not start.
    Pitpower1's Avatar
    Oct 2007
    Re: Sikk Mx 125cc Wont start
    Anyone Pls???
    is Alive and well !!!
    OLDSCHOOL's Avatar
    Oct 2003
    Cape Cod Ma. 02660
    1. take off cam cover
    2. take off flywheel cover
    3. turn flywheel by hand clockwise till flywheel timing mark (T) lines up with case mark (-) 12:00 oclock
    4. while turning the flywheel notice the Cam gear timing mark (o) rotates till it is a 9:00 oclock and aligns with the Head timing mark (-)
    when the (T) mark on the Flywheel is at 12:00 oclock and the Cam gear (o) mark is at 9:00 oclock the piston should be at TDC top dead center
    did you have the motor apart..?
    2006 STIMILON Masters of Mini Stock Class Champion
    BUILDER of mighty mini motors
    making chop suey out of the competition!!!
    Pitpower1's Avatar
    Oct 2007
    Thanks Oldschool... I did this many times. But the piston still at BDC position instead of TDC. I ended up taking the head and cylinder removed to see what is going on inside. But all seems Ok. I still dont understand why the piston is at BDc position when I ligned up the Two timing marks.
    Pitpower1's Avatar
    Oct 2007
    Before taking it apart I removed the carb, when I kicked start it, I feel pressure on the intake port instead of suction.
    OLDSCHOOL's Avatar
    Oct 2003
    Cape Cod Ma. 02660
    What your discribing is the Cam being 180 degrees off....this wouldn't happen unless it was mistakenly put back together wrong
    Pitpower1's Avatar
    Oct 2007
    Bike was never taken apart before this problem occur. I was riding it, I heard a grinding sound inside the motor and it stopped and wont start again. I have replaced cdi and coil but no help. Timing chain is ok, spark is ok, compression is ok, the only thing I see wrong is the position of the piston. It is at Bottom dead center when I align the timing marks. I looked at the crankshaft inside, It looks ok, It make me think now that this is what it is suppose to be.
    OLDSCHOOL's Avatar
    Oct 2003
    Cape Cod Ma. 02660
    Im wondering if the flywheel key sheared...?
    how is the compression?
  10. #9
    Pitpower1's Avatar
    Oct 2007
    Compression is Ok, I looked at the flywheel Key, it looks ok, In fact, I tried to remove the flywheel last nite, It wont come out, it is like welded to the shaft. I used gear puller, it doesnt help. I think I need the special tool to remove it.
  11. #10
    OLDSCHOOL's Avatar
    Oct 2003
    Cape Cod Ma. 02660
    Yes a flywheel puller...
    but you must pay close attension to the crankshaft and not to smoosh the threads when removing the flywheel.
    what we need to figure out is where the piston is when the Flywheel mark and the cam gear mark is at there proper places when TDC timing is observed
  12. #11
    Psychoholic's Avatar
    Jun 2007
    Toronto, Ontario CANADA
    Im thinking that the flywheel might have spun/ sheared the key. There is no reason why you should be @ bdc when the T is @ 12 o'clock
  13. #12
    Pitpower1's Avatar
    Oct 2007
    I will buy a flywheel puller and remove the flywheel so I can see what is going on in the crankshaft/flywheel. From the diagram I saw, the crankshaft is 3 piece, the left and right crankshaft and the journal (which is actually a pin).I am thingking the Left crankshaft might be pressure pressed,if this is so, it is possible that it came loose and shifted the shaft 180 deg. The only way to tell is to remove the fwheel,the bearing and the chain gear. Big deal,It's like tearing the whole motor apart, but what the heck,all I got to loose is the motor, heh heh heh
  14. #13
    OLDSCHOOL's Avatar
    Oct 2003
    Cape Cod Ma. 02660
    where do you live..?
    highly unlikely for the crank to come apart/spin...Key is designed to be the weak link and "shear" to prevent major damage
  15. #14
    Pitpower1's Avatar
    Oct 2007
    I live in Westmont,Illinois. bike is my hobby. I have a Yamaha Virago,Kawasaki Kz550 and this Sick pitbike....
  16. #15
    OLDSCHOOL's Avatar
    Oct 2003
    Cape Cod Ma. 02660
    Quote Originally Posted by Pitpower1
    I asked your location as I have traveled to help People all over New England with there Bikes...
125cc wont start
sikk mx 125 bike wont start
sikk mx 125 pit bike
sikk mx crank shaft
sikk mx no spark
sikk mx pit bike wont start
sikk mx timing
sikk mx toronto
sikk mx wont start
sikk mx wont start no spark
sikk toys mx 125cc kick start
sikktoy 125
