Chinese Engine 250cc Air Cooled Wiring Help
This is a discussion on Chinese Engine 250cc Air Cooled Wiring Help within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Hello, I buy a 250cc engine from china, I need make the wiring harness is for a go kart proyect, from the engine coming: 3 ...
Results 1 to 3 of 3
    gonzalocimma's Avatar
    Feb 2008
    Cleveland, Ohio
    3 yellow wires
    1 black/red
    1 blue/white
    1 green/white
    I think is the stator, the problem is the standard voltage regulator have 4 or 5 wires, my problem is the 3 yellow wires, I think is for lights. I know 1 or 2 go to regulator, but the other?
    The other side coming 6 wires:
    blue/red
    pink
    light green/red
    red/white
    yellow/red
    green/black
    I think is the gear position, this is easy, because is for ground.
    Thanks for help me, I need the wiring harness schematic.
    Gonzalo Cimma
    is full of gas !
    FastMC's Avatar
    Mar 2004
    boston area
    Re: Chinese Engine 250cc Air Cooled Wiring Help
    Sounds like it has a 3 phase alternator. You need a big bike style reg/rect with 3 inputs for the 3 yellow AC wires. That's if you plan on charging a battery and running lights. if you're just running a headlight, I dont see why you couldnt just use 2 of the yellow wires. The blk/red should be your exciter coil and the blue/wht the pulser coil.
    The older I get, the faster I was !
    Feb 2008
    Cleveland, Ohio
    Thanks, I want a charge the battery and run lights too, you think if put a 2 yellow wires in the regulator is ok, and the other don't touch.
    I need know the oil for this engine, 10W40 is ok, and in the side of the spark plug, the engine have a little hole, what is this?
    How put pictures here?
250cc chinese engine wiring
250cc go kart wiring diagram
chinese 250 motor wiring
chinese 250cc wiring harness help
chinese enduro 250 engine wiring with pink wire
chinese engine help
how to simple wire chinese go kart
who makes a wire harness for 250cc chinese go karts
wire harness for 250 cc buggy
wire harness for 250 cc go cart
wire harness for 250cc chinese go cart
wiring diagram for chinese go cart
