GPX 150cc Engine Manual
This is a discussion on GPX 150cc Engine Manual within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Does anyone know where to get a manual for the GPX 150cc engine. Thinking about digging into my engine that came on my pitster x4 ...
Does anyone know where to get a manual for the GPX 150cc engine. Thinking about digging into my engine that came on my pitster x4 pro. Doesn't seem like the pitster manual gives enough information about the engine internals etc. I assume that this GPX motor is just a Lifan with some minor modifications... is this the case? Any help would be appreciated. Thanks!
08-10-2008 04:16 PM
Re: GPX 150cc Engine Manual
(A True MX'er)
If your bikes worth more than your car.
You see perfect berms and jumps everywhere you go.
http://www.myspace.com/136899806
05 Xtreme CR2
99 XR70R
99 Z50R
I took some detailed pictures of the transmission assembly when I tore my motor down. I'd be happy to share if you need.
crf150r,
Don't know if it is a Yx, only that it comes on a Pitster ProX4 bike... and all that I have seen so far is GPX moto 150cc. What is a Yx?
orracle,
That would be good. That is exactly what I am looking for actually. My Pitster has been shifting pretty hard lately after I had a few off track excursions, think I bent a shift fork or something... but don't want to get too deep into it only to not get it back together correctly, you know. If you have some pics I would appreciate them. You can e-mail them to tommygray83@hotmail.com. Thanks!
A yx is a motor that has a crf50 style bottom end, and the top end is a klx110 style. Its a YX150 motor. What oil are you running and how much are you putting? Did you ever change it from when you got it?
(A True MX'er)
05 Xtreme CR2
99 XR70R
99 Z50R
yes. Have changed it twice so far in about 4 times of riding. Vavoline 10-30.
Originally Posted by
125ccRacer
crf150r,
orracle,
sent u an email
- You may not post replies
- You may not edit your posts
Forum Rules
gpx 125 transmission oil
gpx 150 engine
gpx 150 engine case
gpx 150 transmission
gpx 150cc
gpx 150cc manual
gpx engine 150cc specs
gpx motor manual
gpx yx 150 transmission
transmission case for 150 gpx motor
where is the drain for motor oil and gearbox oil gpx 125
yx 150 engine manual
