YX150 vs YX160...compare and contrast...
This is a discussion on YX150 vs YX160...compare and contrast... within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; Originally Posted by Paxracing Do you want the 150 yx kit with the skirted cylinder to make it a 165. Tanya sell the 165 kit ...
Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
  1. #21
    Paxracing's Avatar
    Mar 2004
    ca
    Re: YX150 vs YX160...compare and contrast...
    Quote Originally Posted by Paxracing
    Tanya sell the 165 kit from tb with the skirted cylinder still and good in stock.
  2. #22
    357 Racing's Avatar
    Dec 2006
    Austin, Texas
    I guess it does put less stress on it cause theres less friction on street. Just dont over rev. :X
    (A True MX'er)
    If your bikes worth more than your car.
    You see perfect berms and jumps everywhere you go.
    http://www.myspace.com/136899806
    05 Xtreme CR2
    99 XR70R
    99 Z50R
  3. #23
    50rider340's Avatar
    Mar 2004
    CT
    Quote Originally Posted by nielspbr
    How good is your german Monkey Shop Raubling
    Do not know about reliability though
    not to thread jack but anyone see the like outer rotor kit that has a lighting coil on it to. Damn i wish i could get my hands on that.
  4. #24
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Quote Originally Posted by 50rider340
    FYI...the Lifan 150 mini rotors do come with a lighting coil. Everyone thinks they don't but they do. Problem is that they only generate 35w. My setup on my CT makes 110.
  5. #25
    Banned
    firepower354's Avatar
    Oct 2006
    Flint MI
    PM me for a link to a 63mm skirted jug, and matching piston kit, gaskets, for under $100
    Said jug will take a 65.5mm Akunar for a rebuildup.
  6. #26
    357 Racing's Avatar
    Dec 2006
    Austin, Texas
    Has anyone found where to get the v2 head, 177, and race piston? Are the pistons in the 165/177 kit for the v2 heads?
    Also whats that best to run so I dont have problem? Inner rotor, outer rotor, or flywheel? And where can I get a better slinger compared to the stock unit?
    (A True MX'er)
    05 Xtreme CR2
    99 XR70R
    99 Z50R
yx 150 motor reliability
yx 150 or yx 160 more reliable
yx 150 reliability
yx 150 vs 160
yx 150 vs yx 160
yx 150 vs yx 160?
yx 160
yx 160 stroke
yx150 brand from ahp minis
yx150 vs yx160
yx160
yx160 vs yx150
