Carb problems
This is a discussion on Carb problems within the Chinese/Import Minis - General Discussion forums, part of the General Talk category; ok so my little bro broke his throttle cable on his orion and i got a new one and slapped it on and now his ...
Results 1 to 6 of 6
Thread: Carb problems
    jjpluml's Avatar
    Aug 2008
    SPRINGDALE ARKANSAS
    Carb problems
    ok so my little bro broke his throttle cable on his orion and i got a new one and slapped it on and now his bikes acting up hardcore. The bike will start and run with the choke on but when you turn the choke off it backfires through the carb and pops and then eventuallt dies. The bikes also smoking white in a bad way!!! tried adjusting the needle up to the middle clip but not any better. The plug is soaking wet when i pull it out also so i dunno wtf... HELP!!
    onlydirt's Avatar
    Sep 2007
    Kokomo,IN
    Re: Carb problems
    Tare down the carb, clean it out, make sure the float isnt sticking. Makes sure the throttle cable is long enough, so its not pulling the carb open at all. Re set your idel screw.
    jjpluml's Avatar
    Aug 2008
    SPRINGDALE ARKANSAS
    Re: Carb problems
    where should the idle screw be setting? I mdae sure that the needle was closing all the way, u think the float could do this?
    lemmonbomb's Avatar
    Jan 2007
    Re: Carb problems
    make sure the carb is clean and that the throttle cable has enough travel.
    onlydirt's Avatar
    Sep 2007
    Kokomo,IN
    Re: Carb problems
    I had a bad float on an OKO and it did as you described.
    jjpluml's Avatar
    Aug 2008
    SPRINGDALE ARKANSAS
    Re: Carb problems
    the needle defanitly sets all the way down n the carb. No question. ive just never heard of a float makin a bike run like this
