TB 108, Takegawa clutch, shark oil cooler...
This is a discussion on TB 108, Takegawa clutch, shark oil cooler... within the CRF50/CRF70 Parts For Sale forums, part of the Classifieds category; Ok heres the deal. I need to sell my motor in order to buy something else. If the other bike sells that I am going ...
Results 1 to 5 of 5
    yamaha_rider927's Avatar
    Jan 2005
    Roseville, Ca
    Ok heres the deal. I need to sell my motor in order to buy something else. If the other bike sells that I am going to buy then this motor will no longer be for sale. UNDERSTAND?
    This is what the motor has:
    TB 108cc kit including:
    - 51mm Crankshaft with NTN bearings
    - High compression piston with rings, pin, & clips
    - Race Head (Larger valves and porting for increased performance. Also has bigger cooling fins.)
    - Lightweight aluminum cylinder with steel sleeve, cast in mounts for skid plates, and larger cooling fins.
    - High performance race camshaft
    - 24mm Carburetor kit with intake, airfilter, and throttle cable.
    Takegawa clutch
    Shark oil cooler (Includes all mounting hardware, head plate, oil lines)
    TB super oil pump
    15 tooth counter shaft sprocket
    Entire clutch assembly
    Entire throttle assembly
    FiveO skidplate
    BBR footpeg mount
    IMS Super Stock footpegs
    IMS folding shift lever
    *forgot* Takegawa CDI box
    You will get EVERTHING you need to make this motor run in your frame.
    The ONLY thing wrong is the FRONT LEFT footpeg mount is stripped out. This can easily be repaired by inserting a heli-coil. Other than that the motor is REALLY fast, has tons of torque, and is perfect for any rider. I would like to get $995 SHIPPED FOR IT!!! my email is yz250f_927@yahoo.com or you can call me at 916-223-9052 (cell) or my home at 916-797-0244
    Just the 108 kit alone would cost you $600 not including shipping, then I believe its $250 for the clutch, $130 for the oil cooler, $30 for the super oil pump, and thats not including the cost of buying a stock honda motor. And it comes with even more parts than that! In parts alone I have over my asking price for the entire motor!! On top of that if you bought the kit you would have to pay for it to be installed. This is a great deal. I can get you more pictures if you would like just let me know.
    TP83's Avatar
    Jun 2005
    Woodside, Ca
    I don't know where your getting the pricing for the clutch and the kit but at Factorymotorsports is atleast $100 ofwhat your tellin us.
    Jan 2005
    Roseville, Ca
    Yea for the Trial Bikes clutch! Im not sure if its $250 or $200. But I know its in that price range. If its not then they lowered the price.
    EDIT* I just took the pricing for the motor kit off of www.hondatrialbikes.com
    Ok so yea you can get the kit for $500. So even with that I am selling the motor for LESS than the price of all the parts that I put into it. I think this is a great deal...or is it not?
    seany's Avatar
    Jun 2005
    Concord Ca.
    what do ya want for the cooler???
    VANDAL PRODUCTIONS underground movement
    Hidden Content
    Jan 2005
    Roseville, Ca
    $995 dollars. IT GOES WITH THE MOTOR!! I AM NOT PARTING OUT MY MOTOR!!!
crf50 takegawa oil cooler
shark oil cooler
tb parts crf50 oil cooler
