No oil, locked up motor, what to do?
This is a discussion on No oil, locked up motor, what to do? within the CRF50 forums, part of the General Talk category; Let a friend borrow my bike, the clutch nut came off, and the oil slowly drained out It locked the motor up so the kick ...
Results 1 to 12 of 12
    Towlieee's Avatar
    Feb 2007
    It locked the motor up so the kick starter wont move
    I pulled the head off, and the clutch cover off, and sprayed a little wd-40 on the piston, just to see if it would unlock, and I turned the crank, and moved the piston about 1/2" just to make sure it was free..
    Question is, should I just pop the cylinder, hone it, and slap together and ride? Or should I pop the bottom end apart and inspect inside there?
    Btw even though I turned the motor with the crank, the kick start still didn't move the motor. But I didn't put a ton of pressure one the kicker cause I didn't wanna ruin anything.
    Btw worst comes to worst, my friends going to buy me all the parts I need. but if I can pop it apart, inspect, and just buy new rings and head gasket, then that's all I want to do..
    fiveho's Avatar
    Jan 2006
    indiana,pa
    Re: No oil, locked up motor, what to do?
    check the wrist pin hole in the connecting rod. if it got scarred or galled up from lack of oil your gonna have to split it for sure.
    Flat_Land125's Avatar
    May 2009
    Rockledge, Fl.
    nows your chance to go big bore kit...that sucks though man. Isnt that in one of Murphy's laws anyway..."If it breaks it was meant to be replaced"
    Towlieee's Avatar
    Feb 2007
    Quote Originally Posted by fiveho
    I just took the motor off the bike, and pulled the cylinder off
    the wrist pin IN the piston is ****ED, the piston wont even budge with all my force from the rod..
    However the rod makes full rotations and spins fine
    Also the piston has deep gouges in it, the cylinder wall isn't AS bad, but still has scratches..
    I'm gonna go ahead and split the bottom end just to double check, but the bottom end seems to spin freely, the piston and wrist pin are definitely ****ed, does that mean my rod is ****ed?
    and if my rod is ****ed, I either gotta score a used OEM crank? Or pay the rebuild price? AKA I wont pay the rebuild price, I'll just stroke it for $199 from trail bikes (new crank, piston, and cylinder)
    Towlieee's Avatar
    Feb 2007
    Quote Originally Posted by Flat_Land125
    already running a stage 3 88 kit from honda trail bikes
    It was probably getting low on compression and worn anyways, just sucks it has to go out RIGHT after I break my hand and can't work, and I have traffic tickets to pay.
    And I feel bad having my friend pay for a full stroker kit or somthing.. Going to either try and get it fixed cheap, or try and get him to go in half on the stroker
    Towlieee's Avatar
    Feb 2007
    ahhhh nevermind, trail bikes $199 stroker does NOT come with a new cylinder
    Not sure what I'm going to do, I guess i'll pop the motor apart tomorrow and see how the bottom end is, and try to beat that wrist pin out and see if the rod is ****ed..
    Anyone have any experience? Is my rod probably ****ed? The piston will NOT spin on the rod
    fast88's Avatar
    Nov 2006
    new lenox, IL
    hey i happened to have a stock crank because i just ordered a stroker crank for my bike if you want it you could have it for like 50 bucks
    slapaho16's Avatar
    Apr 2006
    Fort Worth TX
    get ahold of firepower im sure heel hook you up on some fresh parts he may even have a used cylinder and crank
    Riding 50s and slappin hoes
  10. #9
    Banned
    firepower354's Avatar
    Oct 2006
    Flint MI
    Yup
  11. #10
    dville_gt's Avatar
    Apr 2008
    dville, tx
    dr atv has stock replacement cranks (with heavy duty rod) for like 49 bucks. we just put one in my buddies bike after he popped a hole in his piston and ate up his bearings.
  12. #11
    is braaap!
    Pimpindahoes's Avatar
    Apr 2004
    Ontario, California
    i have a stock 50 motor that can be used as is or used for a parts motor becasue it has a broken case and was welded. Works fine but you can take all the internals from this one and put them into your motor that is seized. Will work out perfect for you and cheap.
    $100 plus shipping for the motor.
    Matt
  13. #12
    chubbs's Avatar
    Apr 2009
    Southwick
    Tb rebuild kit is only $66
car motor locked up
engine lock no oil
engine lock up no oil
engine locked up no oil
if the engine locks due to no oil
motor locked up due to no oil
no oil engine lock up
no oil engine locked up
what to do if engine is locked up
what to do if engine locks up
what to do if motor is locked up
what to do if your car engine locked up
